Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: fasteddy] #1056293 01/24/13 12:07 AM
Canyonero Offline
Ditto on that. And make sure whatever you use as a snake has no hook, or sharp edges on it. Or else you could cut one of the many wires back behind the airbox. Like the wire that tells the transmission that its ok to shift into overdrive. <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: off-roader] #1056294 01/24/13 02:11 AM
jdavis Offline
My understanding... remove the plastic fender liner and you have direct access to the antenna assembly however you'll also need to disconnect it from the radio and feed the antenna wire up and out through the hole in the firewall.
Grasscat may have more insight as he's done it before with his. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I did not go through the fender well because it looked like part of cover is riveted to the wheel well and could not easily remove the clips holding the wheel well in place. What's the trick for removing the buggers?
Removing the fender isn't' that hard. One screw behind the door (also a pin but just pull the fender toward front of truck to clear once unbolted), 2 screws underneath, 5ish in the engine compartment, 3 behind the marker light.
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: jdavis] #1056295 01/24/13 03:03 AM
sasnydley Offline OP
Wind Shield washer is in same fender as Antenna? I though it was on opposite side?
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: sasnydley] #1056296 01/24/13 05:22 AM
jdavis Offline
I thought you were talking about the headlight washer.
If it is the wind shield washer the squirters have a tendency to clog. I've cleared mine twice but I wheel a lot in dusty areas. This summer both stopped working. I could hear the pump kick on but no streams of water.
Verified the problem is the squirters by disconnecting the hose at the T under the hood and activating the pump. Bam water came out of the hose.
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: Anybody have nice Diagram or photos of Washer hoses in 95 SR? [Re: jdavis] #1056297 01/25/13 03:56 PM
~ Jon
I have no hoses to disconnect from the T piece.... that is my problem.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6158 MB (Peak: 0.6810 MB) Data Comp: Off Server Time: 2026-06-07 06:56:52 UTC
