1989 Montero Questions #1056450 01/31/13 05:43 PM
MinksMontero Offline OP
I have a 1989 Montero, I am wondering if there are any interchangeable Wiper Arms, the ones on mine are the straight flat on the end ones, I want the ones that have the hook on the end. Second Question: I would like to change my rims to 16's just for ease of sourcing tires, Is there a interchangeable rim from another vehicle that will work? Thanks in advance for your suggestions and advice.
Chris Mink
1989 Mistubishi Montero 3.0
1998 Land Rover Discovery 4.0
Re: 1989 Montero Questions [Re: MinksMontero] #1056451 01/31/13 07:16 PM
Perhaps but honestly not sure. Have always been fine finding wipers that work with the OE setup.
When I bought my latest set of AT's I went through the same thought and found that 15" tires are not only easily available (33" & 35" BFG MT and AT tires) but are a lot cheaper than the same tires made for larger rims. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1989 Montero Questions [Re: off-roader] #1056452 01/31/13 07:21 PM
Thanks for the reply Off-Roader,
Chris Mink
Re: 1989 Montero Questions [Re: MinksMontero] #1056453 02/01/13 02:56 AM
ryany Offline
The GenIII Monteros came with 16" wheels that should fit yours, but unless you're dead set on a specific 16" tire there are more tire choices in the Montero's size range with a 15" wheel.
95 Montero SR
PHP: 7.4.33 Page Time: 2.578s Queries: 15 (0.005s) Memory: 0.6018 MB (Peak: 0.6584 MB) Data Comp: Off Server Time: 2026-06-22 15:21:45 UTC
