1991 Trooper Fuel issues
#1056454
01/31/13 06:05 PM
Hello! Been a while but I'm back with some questions.
In the fall I was driving my trooper and it just died on me. When I pulled over to investigate I found that when I tried to start it no gas was being sprayed out of the injectors. I ended up having to tow it home.
When I tried to start it next it started spraying gas but it looked like FAR too much and the engine wouldn't run unless I was pressing down on the accelerator.
I tried changing the fuel filter but that didn't help.
Any thoughts?
'91 Trooper 3.4 V6, K&N, 33x12.5 Trxus MT's, Aisin hubs, 3" body lift, Rear ARB Naches Trail
Re: 1991 Trooper Fuel issues
[Re: Storm Trooper]
#1056455
02/01/13 12:25 AM
It has been a while. Refresh us on how your rig is set up. What TBI are you running on you rig and I think I remember that you are running a 3.4. Is that right?
[Re: Jim_Paget]
#1056456
02/02/13 07:41 AM
Yep. 3.4 and I have a 4.3 throttle body. Stock fuel system for the rest.
[Re: Storm Trooper]
#1056457
02/02/13 03:57 PM
I would start by carefully checking all the wiring connections to the injectors. I fought similar issues for nearly a year before I went back, re-did all the connections and sealed them so that they are water tight.
