Gen II Body Lift
#1056656
02/08/13 07:31 AM
Contemplating installing one of 4crawler lift kits from the reading I've done it sounds like a relatively straight forward install.
But curious what needs to be extended when the kit is installed - brake lines, fuel filler hose, wiring, etc.... ?
Thanks for any insights.
~ Jon
95 Montero SR 33 x 12.50 Aussie Locker OME Heavy Duty Coils & Torsion Bars ARB Front Bumper 76" Trail Gear Rock Sliders XRC-9.5K Winch
Re: Gen II Body Lift
[Re: jdavis]
#1056657
02/08/13 05:42 PM
Nothing needs to be extended but the brake lines do need to be 'adjusted' at certain points.
Have you checked the FAQ post for a thread on the procedure?
[Re: off-roader]
#1056658
02/08/13 06:00 PM
Have you checked the FAQ post for a thread on the procedure? Did check the FAQ and read a couple of articles on the expedition portal but still find it hard to believe nothing needs to be extended <img src="/forums/images/graemlins/scared.gif" alt="" />. I know you've had yours lifted for quiet some time. So, I'll take your word for it. thanks, ~ Jon
[Re: jdavis]
#1056659
02/08/13 06:29 PM
Only thing I had to do was tweak the brake lines coming through the front fender wells and crank the torsion bars a bit to help with tire clearance. On the 'to do' list is to notch out part of the center console where the 4x4 shifter comes through to gain a little clearance. The bend in the shifter interferes a bit after the body lift. Took me about 1.5 hours start to finish by myself to do the lift. There is a brace in the middle of the truck underneath that I used a floor jack and some scrap wood to lift each side of the truck to install the lift blocks.
1995 Montero SR 2" Body Lift 35x12.50x15 Cooper Discoverer STT Aisins
[Re: jdavis]
#1056660
02/08/13 06:30 PM
I had no issues when I installed mine - I only had to adjust the front hard brake lines where they pass through the front aprons,
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#1056661
02/08/13 06:44 PM
I had no issues when I installed mine - I only had to adjust the front hard brake lines where they pass through the front aprons, Same thing Ryan said. No extra cutting was required.
[Re: jdavis]
#1056662
03/16/13 01:24 AM
Wahoooo!!! The 4 Crawler 2 inch body lift kit arrived today!
[Re: jdavis]
#1056663
03/16/13 01:29 AM
Wahoooo!!! The 4 Crawler 2 inch body lift kit arrived today! Nice!  The install isn't bad at all. Just a bit time consuming. Take your time, have a beer and in a couple hours she'll be all set. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sean - Orange County, CA MAIL: seanwilliams78@gmail.com1995 Montero SR - For exploring and getting away! 1994 Volvo 850 Turbo - 402hp and counting! 1966 VW Bug 2275cc - For stoplight drags!
[Re: socalmonty]
#1056664
03/16/13 02:55 AM
Wahoooo!!! The 4 Crawler 2 inch body lift kit arrived today! Nice!  The install isn't bad at all. Just a bit time consuming. Take your time, have a beer and in a couple hours she'll be all set. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks Sean! Plan on setting aside a weekend to do the lift. Anyone have any tips or tricks for jacking up the truck body? Thanks , Jon
[Re: jdavis]
#1056665
03/16/13 06:03 AM
