4WD with C/D Lock works - open C/D makes crunchy noises
#1057014
02/16/13 05:15 PM
My '92 SR is having 4WD issues.
The truck is great in 2WD. If I shift the transfer case to 4wd hi there is much wailing and gnashing of teeth. The same if I go directly to 4WD Hi Loc.
But if I go directly to 4WD Lo Loc 4x4 works as advertised, I can then go from 4WD Lo Loc to 4WD Hi Loc and all is well. But if I go from there to 4WD Hi with the open diff, there is more wailing and gnashing of teeth. Crunchy noises and vibrations.
Any ideas what the problem could be?
92 Montero SR 84 Maserati Biturbo 89 Mercedes 190E 77 Fiat X1/9
Re: 4WD with C/D Lock works - open C/D makes crunchy noises
[Re: m4ff3w]
#1057015
02/17/13 02:50 AM
The tcase has problems, and the only way to find out what is to take it apart.
I thought that you already had a post started on this topic...
PHP: 7.4.33 Page Time: 2.126s Queries: 15 (0.004s) Memory: 0.5889 MB (Peak: 0.6372 MB) Data Comp: Off Server Time: 2026-06-07 05:57:01 UTCValid HTML 5 and Valid CSS
