Page 3 of 3 1 2 3
Re: Montero HID Conversion [Re: fasteddy] #1057598 03/12/13 02:56 AM
PA_JERO Offline
Yes, I am compensating for rude pricks with unaimed or too bright lights... You endanger others, and deserve no compassion or courtesy or slack. I don't need a .357 for you, of course... all I have to do is say, "Poof", and you disappear from my world.
I first heard this method used about 1977-78, heading west from Hobbs, NM, two of us with three repo vehicles. Somewhere east of Midland, TX, the Permian basin is flat as a billiard table where I-10 goes. Some DA trucker with about Pa's level of couth flipped on 4 aircraft landing lights on his front bumper. This was the heyday of CB radio, and immediately several eastbounders complained about having to drive into the equivalent of the sunrise at 10pm with night adapted eyes. No avail. DA's uberlight was more important to him than common courtesy. Then about 1000watts of linear amplified CB boomed, "I have a .357 magnum with 6 long range dimmer switches...", and the sunrise extinguished. Just remember, there is still somebody out there like that when decide it's "their tough luck". Darwin never sleeps.
Think on this. Your ability to see in the dark depends on a chemical called visual violet in the retina. It is destroyed by light, and takes from 30 minutes to two hours to be replenished, so one blast from your HID lights kills someone's night vision for from half an hour to two hours, sometimes more. This endangers their life. This makes the use of the .357 dimmer switch a legal act, does it not?
Sociopathology is contrasurvival, is it not?
My comment was not meant to offend. I hardly think I stand on ground to go "Poof" from your world seeing as how my comments are sarcastic and you have now decided to take it to a whole new level. Its probably time for you to change your tampon. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
Re: Montero HID Conversion [Re: PA_JERO] #1057599 03/12/13 03:16 AM
ClayTK Offline
Wow I think this got a bit out of control...
1998 Mitsubishi Montero
2" Body lift
35" Cooper tires
Parrot Asteroid Smart w/ factory AMP
Cobra 29 LX CB Radio w/ Firestik MK-DM18R rooftop mount
Aisin Manual hubs
Grote 36 LED, TractorPlus (Wired to factory fog light switch)
Re: Montero HID Conversion [Re: PA_JERO] #1057600 03/12/13 03:18 AM
wrenchwench Offline
I wouldn't waste ammo on headlights, it's frickin impossible to buy anymore <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Montero HID Conversion [Re: wrenchwench] #1057601 03/12/13 03:25 AM
Good point, but I can still find both .38 and .357. What I can't seem to find is my 9x18 Makarov rounds.
I any case, my Gen 1's both sport Sylvania Wide Beams or something like that. Very satisfied. Much better both on and off the road.
If you need additional beamage, get some of theose newfangled LED's in separate housings. Low draw, high output, selectable switch for on/off.
Re: Montero HID Conversion [Re: wrenchwench] #1057602 03/12/13 03:27 AM
Dang Dad, Mom piss in your cereal this morning and then pump you full of LSD?
Musta been the scallops...
Don't worry, some people don't have the ability to understand hyperbole or the discrimination to recognize it, or perhaps I am just indistinguisably subtle... <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Montero HID Conversion [Re: fasteddy] #1057603 03/12/13 03:41 AM
PA_JERO Offline
TouchÚ
Re: Montero HID Conversion [Re: PA_JERO] #1057604 03/12/13 04:46 AM
My opinion is that properly aimed HID's effect oncoming drivers less than the ramped up halogen units. Because the beam is brighter the residual light floods the areas around where your headlamps are aimed better so less need for your lights to be aimed straight ahead.
Re: Montero HID Conversion [Re: TOASTY] #1057605 03/12/13 05:17 PM
ryany Offline
Whether it's an HID or a high powered halogen really doesn't make a difference - what controls the amount of blinding that you're doing to oncoming traffic is the quality of the headlamp lens and reflector design, specifically the low beam cut-off. The vast majority of older US market vehicles, Monteros included, have headlights that don't adequately prevent enough glare when on the low beam setting to allow anything other than stock bulb power levels. Newer vehicles with factory HID systems have headlamps with much better beam cut-offs.
95 Montero SR
Re: Montero HID Conversion [Re: fasteddy] #1057606 03/12/13 06:51 PM
LandRaider Offline
Yall behave... please... <img src="/forums/images/graemlins/lol.gif" alt="" />
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6376 MB (Peak: 0.7428 MB) Data Comp: Off Server Time: 2026-06-10 01:46:59 UTC
