Re: Possible LS1 swap into the Gen1?
[Re: StockRaider]
#1058157
11/12/13 06:18 AM
Bolt up to the tranny is similar. Length of the tranny differs, I would use the final tranny to mock up. I would set the motor first, then do the tranny mount last with the motor and tranny in place, and make the tranny rear output flange and the rear diff pinion flange parallel, or you'll never get rid of the driveshaft vibrations...
[Re: fasteddy]
#1058158
11/12/13 06:42 AM
I was doing a good deal of measuring, and it looks like it won't be very hard to get it to fit. Just a matter of buying some steel and getting things going. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Richard E 1989 Montero - Stock-ish 1989 V6 Auto Raider - 5.3 Vortech Swap. 1987 Mitsubishi Starion 2.6t, soon to be 3.5 1983 Honda XL600R
[Re: StockRaider]
#1058159
11/12/13 09:18 PM
Dude.... 350 = Ain't gonna fit anywhere NEAR a stock configuration. Either gonna be hacking some firewall, or moving the radiator out into the grill.
[Re: LandRaider]
#1058160
11/12/13 11:11 PM
I am removing the AC and moving the rad cradle forward. I am also planning on an external eletric water pump. It won't be the easiest thing Ive done, but I want my Raider to be more of an original build, so I am fine with the extra work.
[Re: StockRaider]
#1058161
11/13/13 07:38 PM
Good Luck!! Certainly not impossible, but sounds like you are in for some serious modifications!
[Re: LandRaider]
#1058162
11/14/13 03:05 AM
Thanks man. I also plan on a solid axle on this Raider as well. Engine comes first because after I have a running truck again, it will force my hand into torching that floppy front end off. <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: StockRaider]
#1058163
02/13/14 04:56 AM
Just ordered a 5.3 "drop out" engine trans including ECU and wiring harness from a 04 Silverado. I will be sure to take alot of pictures. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: StockRaider]
#1058164
02/13/14 05:13 AM
Sweet! This sounds awesome. I'll go get some popcorn <img src="/forums/images/graemlins/cheers.gif" alt="" />
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
[Re: tonygon]
#1058165
02/14/14 12:53 AM
I love getting new parts... <img src="/forums/images/graemlins/smile.gif" alt="" /> ![[Linked Image]](https://scontent-a-lga.xx.fbcdn.net/hphotos-ash3/t1/p180x540/1800355_10153838936035643_1547074092_n.jpg)
[Re: StockRaider]
#1058166
02/17/14 09:27 PM
Just picked up my motor, I plan on starting a whole new future tech thread when the real work begins. <img src="/forums/images/graemlins/smile.gif" alt="" /> ![[Linked Image]](https://scontent-a-lga.xx.fbcdn.net/hphotos-prn1/t1/p180x540/1011078_10153851774145643_1513447465_n.jpg)
