Page 4 of 6 1 2 3 4 5 6
Re: Possible LS1 swap into the Gen1? [Re: StockRaider] #1058157 11/12/13 06:18 AM
Bolt up to the tranny is similar. Length of the tranny differs, I would use the final tranny to mock up. I would set the motor first, then do the tranny mount last with the motor and tranny in place, and make the tranny rear output flange and the rear diff pinion flange parallel, or you'll never get rid of the driveshaft vibrations...
Re: Possible LS1 swap into the Gen1? [Re: fasteddy] #1058158 11/12/13 06:42 AM
StockRaider Offline OP
I was doing a good deal of measuring, and it looks like it won't be very hard to get it to fit. Just a matter of buying some steel and getting things going. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Possible LS1 swap into the Gen1? [Re: StockRaider] #1058159 11/12/13 09:18 PM
LandRaider Offline
Dude.... 350 = Ain't gonna fit anywhere NEAR a stock configuration. Either gonna be hacking some firewall, or moving the radiator out into the grill.
Re: Possible LS1 swap into the Gen1? [Re: LandRaider] #1058160 11/12/13 11:11 PM
I am removing the AC and moving the rad cradle forward. I am also planning on an external eletric water pump. It won't be the easiest thing Ive done, but I want my Raider to be more of an original build, so I am fine with the extra work.
Richard E
1983 Honda XL600R
Re: Possible LS1 swap into the Gen1? [Re: StockRaider] #1058161 11/13/13 07:38 PM
LandRaider Offline
Good Luck!! Certainly not impossible, but sounds like you are in for some serious modifications!
Re: Possible LS1 swap into the Gen1? [Re: LandRaider] #1058162 11/14/13 03:05 AM
Thanks man. I also plan on a solid axle on this Raider as well. Engine comes first because after I have a running truck again, it will force my hand into torching that floppy front end off. <img src="/forums/images/graemlins/lol.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Possible LS1 swap into the Gen1? [Re: StockRaider] #1058163 02/13/14 04:56 AM
Just ordered a 5.3 "drop out" engine trans including ECU and wiring harness from a 04 Silverado. I will be sure to take alot of pictures. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Possible LS1 swap into the Gen1? [Re: StockRaider] #1058164 02/13/14 05:13 AM
tonygon Offline
Sweet! This sounds awesome. I'll go get some popcorn <img src="/forums/images/graemlins/cheers.gif" alt="" />
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: Possible LS1 swap into the Gen1? [Re: tonygon] #1058165 02/14/14 12:53 AM
I love getting new parts... <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1983 Honda XL600R
Re: Possible LS1 swap into the Gen1? [Re: StockRaider] #1058166 02/17/14 09:27 PM
Just picked up my motor, I plan on starting a whole new future tech thread when the real work begins. <img src="/forums/images/graemlins/smile.gif" alt="" />
Richard E
1983 Honda XL600R
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.009s) Memory: 0.6447 MB (Peak: 0.7686 MB) Data Comp: Off Server Time: 2026-07-14 10:39:42 UTC
