Re: Where's the rear diff air pump, and what's this connector for?!
[Re: socalmonty]
#1058521
04/09/13 12:38 AM
If anyone here has wired the rear diff light so it comes on with the pump (or when the R/D Lock switch is switched to ON) I'm curious about why you'd want to change it from the way the factory had it set up. It's designed to tell you when the locker is engaged, rather than just tell you that you've flipped the switch for it.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: ryany]
#1058522
04/09/13 03:49 AM
If anyone here has wired the rear diff light so it comes on with the pump (or when the R/D Lock switch is switched to ON) I'm curious about why you'd want to change it from the way the factory had it set up. It's designed to tell you when the locker is engaged, rather than just tell you that you've flipped the switch for it. Because in order to get my car put back together, I had to cut the pin off the switch, which means the switch isn't a switch anymore - it's just a drain plug. It was getting dark and I didn't have time to remove the diff from the carrier again...had to get the truck finished. <img src="/forums/images/graemlins/wink.gif" alt="" /> Pump on, unless something breaks, pretty much means locker engaged, so that's close enough for me to remove my now-permanent blinky light.
Sean - Orange County, CA MAIL: seanwilliams78@gmail.com1995 Montero SR - For exploring and getting away! 1994 Volvo 850 Turbo - 402hp and counting! 1966 VW Bug 2275cc - For stoplight drags!
