Page 3 of 3 1 2 3
Re: Where's the rear diff air pump, and what's this connector for?! [Re: socalmonty] #1058521 04/09/13 12:38 AM
ryany Offline
If anyone here has wired the rear diff light so it comes on with the pump (or when the R/D Lock switch is switched to ON)
I'm curious about why you'd want to change it from the way the factory had it set up. It's designed to tell you when the locker is engaged, rather than just tell you that you've flipped the switch for it.
95 Montero SR
Re: Where's the rear diff air pump, and what's this connector for?! [Re: ryany] #1058522 04/09/13 03:49 AM
socalmonty Offline OP
Because in order to get my car put back together, I had to cut the pin off the switch, which means the switch isn't a switch anymore - it's just a drain plug. It was getting dark and I didn't have time to remove the diff from the carrier again...had to get the truck finished. <img src="/forums/images/graemlins/wink.gif" alt="" />
Pump on, unless something breaks, pretty much means locker engaged, so that's close enough for me to remove my now-permanent blinky light.
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Page 3 of 3 1 2 3
PHP: 7.4.33 Page Time: 4.668s Queries: 16 (0.003s) Memory: 0.5973 MB (Peak: 0.6619 MB) Data Comp: Off Server Time: 2026-06-09 09:55:13 UTC
