Re: New 2nd Gen owner [Re: Ataki] #1058592 04/17/13 12:48 AM
KrzyDav Offline
the '89 HB didn't have "the holes". So your H.B. is older than your truck. I'd seat that HB and makes sure it fits the crank real tight. It's real soft iron and gets hammered to a larger size hole if it was ever loose.
The H.B. might look simple but it is very important to have a perfect fit and balance. Cheap Dorman ones are available for around $110. I'd get the $180 OME if I had to do it.
dave h.
Re: New 2nd Gen owner [Re: KrzyDav] #1058593 04/17/13 02:38 AM
Ataki Offline OP
Yeah, judging by the somewhat questionable things I've found so far, I'm going to be checking everything very closely.
I still haven't managed to get the pulley off, I need to go get a chain wrench. I may just go ahead and order the OEM pulley.
1994 Mitsubishi Montero LS, Stock (for now)
General class license -KF5UHG
Re: New 2nd Gen owner [Re: Ataki] #1058594 04/17/13 02:43 AM
KrzyDav Offline
woops, sorry about the wheel info,,,was thinking you had gen1 , dispite thread title <img src="/forums/images/graemlins/drunk.gif" alt="" />
The outer puulley part are pretty brittle for a chain wrench instead of the belt wrench in the FSM. ,,,but if your gonna replace it doesn't matter.
dave h.
Re: New 2nd Gen owner [Re: KrzyDav] #1058595 04/17/13 03:13 AM
Ataki Offline OP
Hmm, I didn't even think about d/l'ing the earlier model FSM.
I tried the starter trick, but either the lack of decent grounds, or a weak starter just wouldn't break it loose. I'm trying to be careful, I certainly don't want the broken-bolt issue. I'm thinking a "Big-3" upgrade might not be a bad idea, either.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6114 MB (Peak: 0.6675 MB) Data Comp: Off Server Time: 2026-05-30 01:18:55 UTC
