Page 1 of 3 1 2 3
Offroad supply checklist needed #1058709 04/11/13 02:40 PM
DuCal Offline OP
As any of you who read my posts know I am new to off-road. Before I go out and join a 4WD club or take Jon up on his offer to go out I would like to make sure I have what I need to go. I have done searches and found list with 12 items and some as high as 36 items. I have this.
Well running LWB Monty
Hi-lift
Shovel
Spare tire
Tow strap
Tools with Pickle fork and BFH
grease
ATF,Oil,break fluid
Antifreeze
Spare Upper and Lower Hoses (radiator)
Spare Upper and Lower ball-joints
No brains
Some of these lists I think have item specific for makes.
Seattle WA... (Everett)
1990 Montero LS OME complete, 2"BL,spray-paint.
1990 Montero LS in the 1st stage of rebuild.
2009 Pilot, Bone stock.
"Let me put on my slightly larger glasses".
Re: Offroad supply checklist needed [Re: DuCal] #1058710 04/11/13 03:19 PM
socalmonty Offline
Hi-lift
Shovel
Spare tire
Tow strap
grease
ATF,Oil,break fluid
Antifreeze
No brains
Do a Google search and you'll find dozens of these lists to help you get an idea. Everyone's will differ slightly.
One thing I would recommend is sharing the load between other vehicles (assuming you are going on a group trip) so that there aren't 5 people carrying the same tools/parts/etc. This gives everyone a little more room in their vehicles.
Sean - Orange County, CA
MAIL: seanwilliams78@gmail.com
1995 Montero SR - For exploring and getting away!
1994 Volvo 850 Turbo - 402hp and counting!
1966 VW Bug 2275cc - For stoplight drags!
Re: Offroad supply checklist needed [Re: socalmonty] #1058711 04/11/13 03:37 PM
DuCal Offline OP
I searched and found the lists. I see your point about sharing loads. That must be what the long lists are getting at. I just got confused about how much to take. I did not want to be "that guy" that never has the basics. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Offroad supply checklist needed [Re: DuCal] #1058712 04/11/13 03:58 PM
RECON45 Offline
you have antifreeze but you definitely need to add water to the list.
Re: Offroad supply checklist needed [Re: DuCal] #1058713 04/11/13 04:10 PM
Lizzord30 Offline
No brains
LOL <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" /> <img src="/forums/images/graemlins/notooth.gif" alt="" />
89 Monturbo (RIP now but the heart is in the 90!)
90 Montero with 2.6 turbo swap! (close to finished)
88 Starion MPI T3/T4 Magna M8 head.....
96 Volvo 850
Re: Offroad supply checklist needed [Re: DuCal] #1058714 04/11/13 04:37 PM
socalmonty Offline
I just found this...it's pretty funny. They go over "the list" at about :20 secs. The sarcasm makes a good point - 80% of the things people bring aren't necessary. <img src="/forums/images/graemlins/wink.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
http://www.xtranormal.com/watch/7348071/part-4
Re: Offroad supply checklist needed [Re: socalmonty] #1058715 04/11/13 05:21 PM
DR1665 Offline
Did you catch that ludicrous display last night? Thing about Arsenal is, they always try to walk it in. <img src="/forums/images/graemlins/cheers.gif" alt="" />
If you carry all that, you're a better man than I. As a fellow rookie, I appreciate your concern. On my first trail run last weekend, I took a flat spare, a small box of very basic hand tools (no pickle forks of BFH), oil, coolant, water, heater hose, tow strap, bugout bag (emergency kit). My buddy had one of those very popular air compressors. We ended up needing it.
I recently watched a video where a British guy mentioned "PETROL" - petrol, electrical/charging, tires, radio, oil, lights. Good things to check before you leave, ya know? Got enough gas? Electrical system up to snuff? Will you cell phone/radio work/last? Etc.
Welcome to the fray. This is fun times.
Brian DR1665 | GBXM | Gearheads United.
89 Raider SWB [rock] | 91 Galant VR4 [roller]
Re: Offroad supply checklist needed [Re: DuCal] #1058716 04/11/13 05:50 PM
I have this.
Hi-lift
Shovel
Spare tire
Tow strap
grease
ATF,Oil,break fluid
Antifreeze
No brains
Upgrade the tow strap to a snatch strap. A snatch strap will make recoveries easier and less damage prone. Snatch straps stretch while tow straps don't. You'll want this kind of stretch in a recovery. They are more expensive but well worth it IMHO.
Basic mechanic set with socket, open/closed end wrenches, screw drivers.
Oil: 6 qt.
Tranny: 1 qt.
Brake: 1 sm bottle
Coolant: 1 gal
Gas: 5 gal. Use a NATO can or a scepter can. Both are good quality and don't leak fumes. Blitz style Jerry cans with a screw on metal cap are not so leak free.
Canvas tarp: I use an old marine corp nylon blanket. Great to cover the ground when you have to lay in it. Also good to put dirty broken parts in after a trail breakdown or as a blanket should you forget your sleeping bag (like on a "3 hr tour" trip) or if its not be warm enough.
ABC fire Extinguisher: This should either be securely mounted or stored because in an accident they will become a heavy projectile.
Water: 5 gal (recommend a dedicated container like the military scepter made for water) but any setup works really.
Energy Bars: 1 box.
Camping gear.
There's probably more. I keep a lot of these things in my rig like the basic tools and extinguisher. The rest I keep in a box ready to go on my next outing.
Re: Offroad supply checklist needed [Re: off-roader] #1058717 04/11/13 06:34 PM
I once brought a bag of chips and a sleeping bag out wheeling just in case. I always have a few gallons of water in my vehicles, mandatory Az stuff.
Re: Offroad supply checklist needed [Re: DuCal] #1058718 04/12/13 01:02 AM
Bernoulli Offline
If you don't have a Gen1, you'll need extras for your Hi-Lift so you can actually use it. I carry a come-a-long - a good one, not a $20 POS. A repair manual is handy.
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6427 MB (Peak: 0.7711 MB) Data Comp: Off Server Time: 2026-06-17 02:27:43 UTC
