Camshaft Sprocket Issue!!! #1058940 04/16/13 03:34 AM
MinksMontero Offline OP
I have been trying to get my 89 Gen 1 V6 running and keep running into problems. Now the left side camshaft sprocket has alot of play in it. I took it off and the recess that the camshaft goes into is 1/16" of an inch too big. The camshaft end measures 1 1/4" the recess in the sprocket measures 1 5/16", Does anyone have a spare sprocket they could measure to see if the shaft I have is incorrect, it was changed, or if I need a new sprocket. Any help is appreciated, any suggestions for my situation will also be appreciated.
Thanks
Chris Mink
1989 Mistubishi Montero 3.0
1998 Land Rover Discovery 4.0
Re: Camshaft Sprocket Issue!!! [Re: MinksMontero] #1058941 04/16/13 04:26 AM
Camshaft sprockets aren't too expensive. Buy another and be done. They are a wear part anyway.
Re: Camshaft Sprocket Issue!!! [Re: rxinhed] #1058942 04/16/13 05:31 PM
Thanks, yeah after closer inspection it was worn and it actually wore out 1/16"
Chris Mink
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5918 MB (Peak: 0.6455 MB) Data Comp: Off Server Time: 2026-06-18 20:22:22 UTC
