The build begins #1059104 04/22/13 02:39 AM
jdavis Offline OP
I picked up another 94 SR a year or so ago with a bad engine for $400. The engine has a really bad knock coming from the lower end.
Plan on building it up to replace my current off-roader. High level plans are:
  • Rock sliders
    OME heavy duty springs
    OME heavy duty torsion bars
    Longer shocks
    ARB Bumper
    10K Winch
    Storage Unit in rear
    Plus other goodies
Any suggestions for the build list always appreciated.
But first have to deal with engine. I pulled the old engine out a while back and have been waffling on how to replace. Finally pulled the trigger on an engine in CA with 89K on it that is now on the engine stand.
While the engine is on the stand planning on replacing timing belt , tensioners, bolt and washer along with the water pump. Anything I should do to it while on the stand?
Thanks,
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
OME Heavy Duty Coils & Torsion Bars
ARB Front Bumper
76" Trail Gear Rock Sliders
XRC-9.5K Winch
Re: The build begins [Re: jdavis] #1059105 04/22/13 03:15 AM
Canyonero Offline
With 89K, it may not need it, but the valve stem seals are a LOT easier to do with the engine on the stand. I'd say look at your rear cam seals as well to see if they need replacing.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: The build begins [Re: Canyonero] #1059106 04/24/13 02:57 PM
jdavis Offline OP
5 boxes of parts left Rockauto yesterday <img src="/forums/images/graemlins/kewl.gif" alt="" />
Didn't think about the seals. While doing the seals should I replace the lifters as well to deal with the ticking issue.
I'll try to get some pics of the truck up later this week.
Thanks,
~ Jon
95 Montero SR
33 x 12.50
Aussie Locker
ARB Front Bumper
XRC-9.5K Winch
Re: The build begins [Re: jdavis] #1059107 04/24/13 04:26 PM
Canyonero Offline
Didn't think about the seals. While doing the seals should I replace the lifters as well to deal with the ticking issue?
We did the lifters along with the seals when freshening up Lloyd's engine for that reason. But I suffer from an extreme case of "while I'm in there" when working on my own rig. You're going to be torn down that far anyway, so if you've got the funds, it can't hurt if your ticking problem is bad.
1995 Montero SR
2" Body Lift
Aisins
Re: The build begins [Re: Canyonero] #1059108 04/24/13 05:12 PM
justrob Offline
Your crazy if you dont do it "while your in there"
PHP: 7.4.33 Page Time: 1.258s Queries: 15 (0.004s) Memory: 0.6067 MB (Peak: 0.6728 MB) Data Comp: Off Server Time: 2026-06-06 23:00:39 UTC
