Needed Badly: '94-'98 SR Oil Cooler
#1059290
04/29/13 01:14 AM
The oil cooler in my SR is cracked at the fittings and is leaking profusely. I am looking for the cooler, bracket, stay, gaskets and bolts.
Please pm if you have available.
Thanks in advance!
Re: Needed Badly: '94-'98 SR Oil Cooler
[Re: MrJeebs]
#1059291
04/30/13 04:58 AM
untill you get what you need, you can disconnect the hoses at the engine and screw in some oil pan plugs(that's how mine is , temporarily), I think they are 16mm. If you find one in a salvage yard make sure it's not off a C4C.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.5862 MB (Peak: 0.6336 MB) Data Comp: Off Server Time: 2026-07-15 02:51:15 UTCValid HTML 5 and Valid CSS
