ECU 90 Montero 3.0 V6 *DELETED*
#1059330
05/01/13 01:44 AM
Seattle WA... (Everett) 1990 Montero LS OME complete, 2"BL,spray-paint. 1990 Montero LS in the 1st stage of rebuild. 2009 Pilot, Bone stock. "Let me put on my slightly larger glasses".
Re: ECU 90 Montero 3.0 V6
[Re: DuCal]
#1059331
05/01/13 02:13 AM
This will blow your mind. I am out front pulling the ECU, dude walks up asks if its burned. I say yup, (just a little frustrated). He knocks on my screen about 10 mins ago with an ECU in hand and says "Merry Christmas". I just about cried!............ In a totally manly way, of coarse. <img src="/forums/images/graemlins/notooth.gif" alt="" />
[Re: DuCal]
#1059332
05/01/13 03:20 PM
Be careful you might have a bad TPS and that is known to burn an IC in the computer. Installing the new one without replacing the TPS might have the same consequences.
Javy
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
[Re: JAVYPRO]
#1059333
05/02/13 02:18 AM
[Re: DuCal]
#1059334
05/02/13 03:46 AM
I think it's the idle control servo that shorts out when it's disolved with solvent and burns out the ECU.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
[Re: JAVYPRO]
#1059335
05/02/13 04:15 AM
I think it's the idle control servo that shorts out when it's disolved with solvent and burns out the ECU. Correct... Be careful you might have a bad TPS and that is known to burn an IC in the computer. Installing the new one without replacing the TPS might have the same consequences. Not so much. <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> ;-) Seriously though... Also read its the ISC that can take out an ECU on one of the ecu repair websites
[Re: off-roader]
#1059336
05/02/13 10:02 PM
Idle control servo?, is that the same as the idle air controller? Never herd of and ICS. If its the IAC then that would make sense.... Cuz I just replaced it... It was FUBAR.
[Re: DuCal]
#1059337
05/02/13 10:37 PM
Idle control servo?, is that the same as the idle air controller? Never herd of and ICS. If its the IAC then that would make sense.... Cuz I just replaced it... It was FUBAR. There are many names because there isn't an industry standard one so different manufacturers call it different things. Idle Speed Controller = Idle Air Controller = ISC/ICS = IAC HTH... <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: off-roader]
#1059338
05/02/13 11:04 PM
Yah, Idle was off, replaced IAC, then stuff went haywire found bad ECU. So, I'll put in this new ECU and should correct the issues. Thank you all for the help. <img src="/forums/images/graemlins/cheers.gif" alt="" />
[Re: DuCal]
#1059339
05/02/13 11:17 PM
Yah, Idle was off, replaced IAC, then stuff went haywire found bad ECU. So, I'll put in this new ECU and should correct the issues. Thank you all for the help. <img src="/forums/images/graemlins/cheers.gif" alt="" /> Before you replace the new ECU confirm the IAC is still good. The ECU repair places mentioned that a bad ecu can make the IAC go bad and vice versa. The procedure to check the IAC is in the FSM. I don't have access to mine right or I'd post the process here.
