Re: ECU 90 Montero 3.0 V6 [Re: off-roader] #1059340 05/03/13 12:31 AM
haztoys Offline
Yah, Idle was off, replaced IAC, then stuff went haywire found bad ECU. So, I'll put in this new ECU and should correct the issues. Thank you all for the help. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Before you replace the new ECU confirm the IAC is still good. The ECU repair places mentioned that a bad ecu can make the IAC go bad and vice versa.
The procedure to check the IAC is in the FSM. I don't have access to mine right or I'd post the process here.
I think its a chicken and the egg thingy...
What kills what or even if one is killing the other ...
The people I've spoke to in the ECM Repair World.. Its more of running a bad IAC for a long time that kills the ECM ... Not like the IAC dieds and zaps the ECM instantly.. I was told the IAC will short to ground is what does it..
I've "me" have never come across a IAC that was shorted to ground ... Not saying it cant happen,, true me ...Just I've never come across it ...
Re: ECU 90 Montero 3.0 V6 [Re: haztoys] #1059341 05/03/13 12:42 AM
I def agree <img src="/forums/images/graemlins/kewl.gif" alt="" /> and that's why he should check it first and make sure the servo's still good before putting the new ecu in. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: ECU 90 Montero 3.0 V6 [Re: off-roader] #1059342 05/03/13 03:47 AM
DuCal Offline OP
I have the procedure in front of me. Ill get it done Sunday and post if I have any issues. Thank you
Seattle WA... (Everett)
1990 Montero LS OME complete, 2"BL,spray-paint.
1990 Montero LS in the 1st stage of rebuild.
2009 Pilot, Bone stock.
"Let me put on my slightly larger glasses".
Re: ECU 90 Montero 3.0 V6 [Re: DuCal] #1059343 05/08/13 02:00 PM
DuCal Offline OP
Ok, all done. Everything checked out. Works perfectly and back in the dirt. I am sending the old ESU out for repair so I have a spare. Thank you for all your help.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6096 MB (Peak: 0.6661 MB) Data Comp: Off Server Time: 2026-06-20 18:06:05 UTC
