Re: Part number for 3.0L 24V cam plug O-rings? [Re: off-roader] #1059454 05/07/13 01:55 AM
MrJeebs Offline
I think this may be what he needs? Highlighted line in 2nd image is o ring at back of head
<img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Part number for 3.0L 24V cam plug O-rings? [Re: MrJeebs] #1059455 05/07/13 02:50 AM
Czd3my Offline OP
THANKS! That is the one! Now I guess I should post it over on the part number thread!
I'm going to have to find something that will run that program! That would be great for finding parts.
1998 Montero (CW Pack)
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: Part number for 3.0L 24V cam plug O-rings? [Re: Czd3my] #1059456 05/07/13 05:13 AM
It should... It's the actual dealer software. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Part number for 3.0L 24V cam plug O-rings? [Re: off-roader] #1059457 05/24/13 03:00 AM
Czd3my Offline OP
Ok...so to follow up and add a few things I finally got time to get these o-rings installed. Easy job! 45 minutes TOPS! Left side from the bottom and right side from the top. One thing, buy yourself a rubber plug to plug the lower trans dipstick when you remove it to keep junk from falling in. Use your light from the top on the left side, you can see better and tie up that wire loom to something up top so it stays out of your way! Mine came out fairly easy and the engine was cold. Get them moving by twist them a couple times back and forth and they pull out easy!
Thanks again for all the help!
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: Part number for 3.0L 24V cam plug O-rings? [Re: Czd3my] #1059458 05/30/13 05:30 AM
motero Offline
I just matched up some o rings from the auto parts store, they have lasted for 5 years but are now leaking. Good job on yours.
99 Montero....15mpg! Sold (so sad)
02 Jetta TDI....48mpg!
03 2500 Ram QCLB Cummins....18mpg
02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold)
01 montero limited
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.014s) Memory: 0.6135 MB (Peak: 0.6789 MB) Data Comp: Off Server Time: 2026-11-04 19:59:37 UTC
