Re: Part number for 3.0L 24V cam plug O-rings?
[Re: off-roader]
#1059454
05/07/13 01:55 AM
I think this may be what he needs? Highlighted line in 2nd image is o ring at back of head ![[Linked Image]](http://i923.photobucket.com/albums/ad80/MrJeebs/Camseals_zpsdba62c69.png) ![[Linked Image]](http://i923.photobucket.com/albums/ad80/MrJeebs/44bba47d-f00c-48bf-ac36-33e73b8f73cc_zpsd191f44d.jpg) <img src="/forums/images/graemlins/patriot.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
[Re: MrJeebs]
#1059455
05/07/13 02:50 AM
THANKS! That is the one! Now I guess I should post it over on the part number thread!
I'm going to have to find something that will run that program! That would be great for finding parts.
1998 Montero (CW Pack) 1979 Chevy LUV 4x4 2000 GMC 2500 4X4
[Re: Czd3my]
#1059456
05/07/13 05:13 AM
I'm going to have to find something that will run that program! That would be great for finding parts. It should... It's the actual dealer software. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: off-roader]
#1059457
05/24/13 03:00 AM
Ok...so to follow up and add a few things I finally got time to get these o-rings installed. Easy job! 45 minutes TOPS! Left side from the bottom and right side from the top. One thing, buy yourself a rubber plug to plug the lower trans dipstick when you remove it to keep junk from falling in. Use your light from the top on the left side, you can see better and tie up that wire loom to something up top so it stays out of your way! Mine came out fairly easy and the engine was cold. Get them moving by twist them a couple times back and forth and they pull out easy!
Thanks again for all the help!
[Re: Czd3my]
#1059458
05/30/13 05:30 AM
I just matched up some o rings from the auto parts store, they have lasted for 5 years but are now leaking. Good job on yours.
99 Montero....15mpg! Sold (so sad) 02 Jetta TDI....48mpg! 03 2500 Ram QCLB Cummins....18mpg 02 2500 Yukon XL, We out grew the montero, at least it has one locker.....13mpg (sold) 01 montero limited
PHP: 7.4.33 Page Time: 0.032s Queries: 15 (0.026s) Memory: 0.6147 MB (Peak: 0.6801 MB) Data Comp: Off Server Time: 2026-11-04 20:00:27 UTCValid HTML 5 and Valid CSS
