what amp fuse
#1059647
05/13/13 04:51 PM
I need to know what size fuse I need for battery terminal--there is a "block" on one of my battery cables that has 3 fuses in it. I need to know what amperage they are and what they are for? I have 3.0, 1989. Thanks.
Gary
Re: what amp fuse
[Re: bearingman]
#1059648
05/13/13 06:22 PM
Not sure of the top of my head nor can I look it up right now but you should be able to look it up in the factory service manual or your owners manual...
Re: what amp fuse
[Re: off-roader]
#1059649
05/13/13 09:55 PM
that's a 100 amp. White wires coming off that one. You need to remove the bolts inside the little box to change it.
dave h. '89 Raider V6 5spd;Aisin Hubs;; Gen2 LS: frt. brakes, rear coils;U.C.arms;R.trailing arms;idler arm; rear LSD axle w.disc brakes ;2 battery system for Dog's fan; relocated ECU; custom bumpers;J.Baker receiver;Conferr roofrack; t-bar crank.
Re: what amp fuse
[Re: KrzyDav]
#1059650
05/13/13 10:13 PM
that's a 100 amp. White wires coming off that one. You need to remove the bolts inside the little box to change it. Dave IIRC the 3 fusible links are not all the same so that's why I'm suggesting checking it in the FSM unless somebody can tell him the correct value for each. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: what amp fuse
[Re: bearingman]
#1059651
05/13/13 11:18 PM
My '89 3.0 MT says, left to right, ALT-100, HEADLP-40, MPI-30.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6075 MB (Peak: 0.6722 MB) Data Comp: Off Server Time: 2026-07-14 12:34:07 UTCValid HTML 5 and Valid CSS
