Gen 2/2.5 rear speaker removal. #1059691 05/14/13 09:11 PM
justice Offline OP
I want to replace the rear set of speakers in my 99. Looks like I have to pull the entire interior panel to get at them? is there a trick to it I'm not seeing?
Re: Gen 2/2.5 rear speaker removal. [Re: justice] #1059692 05/14/13 09:45 PM
Correct. It's easier than it sounds, however. Get a set of Harbor Freight trim panel removal tools for $8, remove the screwed-in trim and start popping loose the panels. It only takes a few minutes, really.
Re: Gen 2/2.5 rear speaker removal. [Re: JohnnyBfromPeoria] #1059693 05/15/13 09:56 PM
ryany Offline
If you've got 3rd row seats they'll have to come out also, along with the seatbelt mounting points. The trim around the windows has to be pulled loose at the bottom also, as well as the rear cargo door threshold trim plate. It's tedious - just when you think you've got the trim panel off there's something else to remove.
95 Montero SR
Re: Gen 2/2.5 rear speaker removal. [Re: ryany] #1059694 05/16/13 02:48 PM
justice Offline OP
Thanks. I need to take the 3rd row seats out anyways. so I'll kill a couple birds with one stone here. Also, do you know what size they are (the speakers)?
Re: Gen 2/2.5 rear speaker removal. [Re: justice] #1059695 05/16/13 03:22 PM
WigWiggy Offline
6x9
98 Montero, 184k.
Re: Gen 2/2.5 rear speaker removal. [Re: justice] #1059696 05/16/13 03:24 PM
Ataki Offline
The rears are 6x9, I believe.
NVM, Got beat to it <img src="/forums/images/graemlins/lol.gif" alt="" />
1994 Mitsubishi Montero LS, Stock (for now)
General class license -KF5UHG
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6099 MB (Peak: 0.6795 MB) Data Comp: Off Server Time: 2026-06-22 08:04:32 UTC
