Wiring in an additional reverse light #1059866 05/20/13 05:25 AM
Mudraider Offline OP
Harbor Freight has these lights on sale.
http://www.harborfreight.com/12-volt-halogen-vehicle-work-light-93904.html
I have used them for lights on the front, doing the normal relay/switch/idiot light wiring. We have a night ride coming up, and the stock reverse lights leave a little bit to be desired. Anyone had experience with wiring a light like this into the standard reverse light wire and not thru a switched relay. Bumping up the fuse is mandatory, and I'm thinking it may not be as bright as when I wire them up on the work trucks, or tractors, but it has to be an improvement over stock
Re: Wiring in an additional reverse light [Re: Mudraider] #1059867 05/20/13 11:36 AM
P
pcc Offline
I was able to replace my stock reverse bulbs for halogens, helps a little.
Direct wire would depend on amperage. On my pickup I installed the relay for add-on reverse lights behind the rear light lens for signal wire, then direct wired it to battery for power.
Re: Wiring in an additional reverse light [Re: pcc] #1059868 05/20/13 01:09 PM
Lizzord30 Offline
I would recommend to use a fuse not directly to battery smile But I have considered doing the same thing stock backup lights are not so great. for $7 thoes look pretty cool!
89 Monturbo (RIP now but the heart is in the 90!)
90 Montero with 2.6 turbo swap! (close to finished)
88 Starion MPI T3/T4 Magna M8 head.....
96 Volvo 850
Re: Wiring in an additional reverse light [Re: Lizzord30] #1059869 05/20/13 02:44 PM
Yes, $7 is a great price. And they work great. They aren't silly bright like the Rigid's or all their knock-offs, but I'm not trying to blind ants on the ground either.
Re: Wiring in an additional reverse light [Re: Mudraider] #1059870 05/20/13 02:53 PM
MBrannon Offline
You could either run it directly in parallel off of the stock lights, or run it's own power source to it with a relay and run the relay power from the stock lights.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Wiring in an additional reverse light [Re: Mudraider] #1059871 05/21/13 02:20 PM
sasnydley Offline
So when where are you "night riding"?
Re: Wiring in an additional reverse light [Re: sasnydley] #1059872 05/21/13 02:55 PM
Hardrock MX and 4x4 Park in Ocala. Look at the events page. Look me up on FB. Frank Eck
Re: Wiring in an additional reverse light [Re: Mudraider] #1059873 05/22/13 11:00 PM
sasnydley Offline
I will. We need need some place relatively close to go play. <img src="/forums/images/graemlins/kewl.gif" alt="" />Since I am back on 12 hr shifts and my nephew who is a medic and is also on shifts (he has 89 2dr V-6) <img src="/forums/images/graemlins/patriot.gif" alt="" />
Re: Wiring in an additional reverse light [Re: sasnydley] #1059874 05/23/13 02:56 AM
Hardrock in Ocala is only a couple hours away. Nowhere else in Florida are you gonna 200 yard hills on a 60? slope. June 8th, plenty of timeto get a schedule changed.
Re: Wiring in an additional reverse light [Re: Mudraider] #1059875 05/24/13 08:28 PM
sasnydley Offline
Going to look into it. Thanks!
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6390 MB (Peak: 0.7606 MB) Data Comp: Off Server Time: 2026-06-07 07:13:20 UTC
