Page 2 of 3 1 2 3
Re: Possible location/cause of interior water leak? [Re: Czd3my] #1060305 06/07/13 04:38 AM
Smoke testing would work if I could find a source of smoke that didn't make it smell like a rib factory or an ashtray for the next two years! LOL!
Just sayin' <img src="/forums/images/graemlins/smile.gif" alt="" />
There's something that covers this description in WA and CO now...
<img src="/forums/images/graemlins/drunk.gif" alt="" />
Re: Possible location/cause of interior water leak? [Re: rxinhed] #1060306 06/07/13 07:48 PM
Czd3my Offline OP
That was my first thought! Where can I find a bunch of stoners...hmmmmm...
1998 Montero (CW Pack)
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: Possible location/cause of interior water leak? [Re: Czd3my] #1060307 06/07/13 11:11 PM
Bernoulli Offline
Rib factory! Mmmmmmmm!
89 3L V6 5spd SWB, Aisin Manual Hubs, 2 (suspension) seater Raider in Wheeler, OR
Re: Possible location/cause of interior water leak? [Re: Czd3my] #1060308 06/08/13 12:01 AM
Based on a 60's trip thru that area with some Cherokee relatives, the rez might be a good place to start.
Got a dog? Use the pressurized method with some fresh cooked bacon inside and let the dog sniff around the car...
Re: Possible location/cause of interior water leak? [Re: fasteddy] #1060309 06/08/13 01:35 AM
Pete_D Offline
Smoke would be best and the most advanced - but if you can pressurize the inside with a reversed vacuum then spray the outside area you suspect with soapy spray to see where the bubbles enlarge. Then trace down with a spray bottle that you can squirt directionally. Before smoke this was the next best thing.....sometimes the blower motor would be strong enough pulling in the outside air but these rigs need a lot of air flow to pressurize.....
3=(PI.98 SWB 2.8TD-TH92.LWB 2.8TD)Red90 SWB.V6/bal,forged pistons,bore/95SR lkr&spr/2 bouncies/(ARB.w/Gorilla 12K winch/new stg gear/stg&sus/CJ side mirr/cust tow rec/01 SR wh w/Mich 265-70-16LTX/Rancho5000's/Candy Apple/rock crawlers/Hellas/KC's
Re: Possible location/cause of interior water leak? [Re: Pete_D] #1060310 06/08/13 04:18 AM
Czd3my Offline OP
Got three dogs and they love bacon drippings on their food so that might work. Although they are awfully lazy!
Never thought about soap and water, just like checking for a leak on a newly installed gas line. I really might give this a try! I am going to go over it and look at everything again in case I'm missing the obvious. Hopefully I'll get time this weekend...
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: Possible location/cause of interior water leak? [Re: Czd3my] #1060311 06/08/13 12:48 PM
Pete_D Offline
FORGOT - FORGOT - FORGOT - sorry - thought of it as I was driving around - painters tape is your friend - tape the seal areas away from the area you are testing so you will have less air volume loss and it will center the air to your area of concern.....
Re: Possible location/cause of interior water leak? [Re: Pete_D] #1060312 06/10/13 01:20 PM
Czd3my Offline OP
Well, I ordered one of those cheap USB inspection cameras to help out. I will probably wait until that comes in to really tackle this. I need a new windshield anyway so I think I'll get that out this week and get a new one put in. I'll check the pinch weld while I'm at it.
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: Possible location/cause of interior water leak? [Re: Czd3my] #1060313 06/14/13 02:07 PM
Czd3my Offline OP
So I was poking around yesterday and found out there is water coming in on the floorboard on the passengers side too! Still have no idea where it's coming from! I am going to pull the dash out and start from there...it probably needs all cleaned and tightened anyway...
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Re: Possible location/cause of interior water leak? [Re: Czd3my] #1060314 09/08/13 02:30 AM
Czd3my Offline OP
So...Finally got back to my leak after working on my pond for several months! Still no luck! Used smoke and sealed it off but not productive since smoke comes out the doors, door seals, you name it! Tried blowing it with air again and using soapy water...no luck either! Ran water out the end of the hose. Cannot make it leak on purpose! I pulled the roof rack and painted it and sealed the screws and the inserts, just in case! Haven't had rain in a while! So I've tried an oscillating sprinkler but nothing yet. Plan now? Paint the floor with undercoating/bedliner and call it good. If it leaks I will just dry it out! It's aggravating me to no end.....
1979 Chevy LUV 4x4
2000 GMC 2500 4X4
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6432 MB (Peak: 0.7515 MB) Data Comp: Off Server Time: 2026-06-17 04:18:50 UTC
