Re: Need a better brake booster [Re: jwthemechanic] #1060581 06/14/13 09:45 PM
A
age67 Offline
Most large cars had them Olds, Pont' etc. Use an oj can and solder some fittings into the end.
Eddie
'88 Dodge Raider 2.6L, 5 spd.
Re: Need a better brake booster [Re: age67] #1060582 06/14/13 10:28 PM
haztoys Offline
Big old school Jeep Wagoneers will get you the big and small soup can ...Last of the Dodge straight axle trucks theres one hiding on the trans cross member is a plastic ball... Some S10 chev ...Lots of 70s 80s Fords cars and trucks "with" oem cruise control...Most Mercurys and Lincolins of the 70s and 80s ..Water cooler VW and Audi have one bolted to the underside of the hood a mess of round plastic balls and its very flat ...Thats all I can think of right now theres more ....I "think" cruise control has a lot to do with a car having one ...New cars are ele cruise ..Old cars are vac cruise ...
Re: Need a better brake booster [Re: haztoys] #1060583 06/16/13 09:53 PM
jwthemechanic Offline OP
Thanks! I have a 85 dodge that prolly has one up in north florida.
"Turbobitchero" (named by jealous wife) 87 swb base, 89 starion intercooled turbo engine, Bouncy seat, posi in rear, "miller locked" in the front with manual hubs, 3" BL, 305/70/16 bfg's. Sponsored by IAWDLR Racing
Re: Need a better brake booster [Re: jwthemechanic] #1060584 06/17/13 12:32 AM
What is 'prolly'?
Re: Need a better brake booster [Re: rxinhed] #1060585 06/17/13 03:04 AM
Sorry for the southern terminology, been in Florida too long.
Re: Need a better brake booster [Re: jwthemechanic] #1060586 06/17/13 03:13 AM
Do the V6 brake swap, adding Gen 2 calipers and rotors if you want more.
Re: Need a better brake booster [Re: MontyMcV] #1060587 06/18/13 12:52 AM
It was the booster after all. Worked perfectly before the engine swap. This explains the trouble I was having resetting the TPS/ISC. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6225 MB (Peak: 0.6966 MB) Data Comp: Off Server Time: 2026-06-21 01:28:48 UTC
