Page 7 of 13 1 2 5 6 7 8 9 12 13
Re: New Owner in Az [Re: JohnnyBfromPeoria] #1060961 11/10/13 04:44 AM
ryany Offline
If the pan is leaking, take it back off. Put it on a known flat surface. Turn it upside down and lightly tap the bolt holes so they are flush. Recheck flatness. Use RTV sparingly and don't get ANY in the pan. Stuff works, but use it in moderation and in combination with the gasket, both above and below it. Do not overtighten the pan bolts; pay attention to the factory specs and if you don't know them, ask us and we'll look it up.
What he said^^^^.
There's something going on that's more than just the gasket, and I'm suspecting the mating flange on the pan as John suggested. Have you pinpointed the source of the leak, as in, specifically which portion of the pan it leaks from? Baby powder or corn starch works well to track down leaks - dust some on the pan flange and check it for fresh wet spots after a while. That'll give you an idea of which part of the pan to closely check the flange for warpage and distended bolt holes from overtightened pan bolts.
95 Montero SR
Re: New Owner in Az [Re: JohnnyBfromPeoria] #1060962 11/12/13 09:29 PM
Tetecorsa Offline OP
Johnny, Yep I was thinking of using ULtra Grey RTV. as for a;; the research suggest its transmission safe and used on jeep regularly. I'll probably do it tomorrow or Thurs. I'll let you guys know how it goes.
Re: New Owner in Az [Re: Tetecorsa] #1060963 12/09/13 03:10 PM
So last week I took a day off and replaced the gasket. Except using the OEM gasket I used the permatex right stuff. Supposed to be good stuff and looks to be working. The pan did not have issues of warped holes or etc It sat flat on the counter top edge as the dip stick holder won't let you set the entire thing on the counter flat. However now have another leak. <img src="/forums/images/graemlins/angry.gif" alt="" /> <img src="/forums/images/graemlins/angry.gif" alt="" />
Looks to be where the linkage goes into the tranny. On the drivers side just above the transmission pan. Looks to be an o-ring. I'll have to get underneath it again and inspect better. Probably Thursday. Pisses me off. All I want to do is take this thing on some trails.
Glad to see everyone is doing good and hit me up with the next meet. I wanna see Adams Toyota get going. The will be pretty rad.
Re: New Owner in Az [Re: Tetecorsa] #1060964 12/09/13 04:46 PM
I think i did the shift selector o ring once before, may have been NP231 but it's probably the same procedure. I took off the shift linkage, removed a little washer and spacer from underneath it and dug the seal out with a seal pick. Cleaned the bore and installed a new o ring, replaced the washer, spacer and linkage, done deal. Took me a bunch of seconds.
Re: New Owner in Az [Re: TOASTY] #1060965 12/10/13 02:28 AM
This was my plan. Seal pick etc and pop new one in. It seems to leak pretty good when warmed up. Hopefully this will be the end of my tranny woes. If not I am contemplating just pulling it out and going over the entire thing. Going nuts dealing with this.
Re: New Owner in Az [Re: Tetecorsa] #1060966 12/10/13 02:30 AM
ryany Offline
Saturday morning, 8:00am, Chevron at I-17 & Carefree Highway. Gonna be some wheelin' goin' on.
95 Montero SR
Re: New Owner in Az [Re: ryany] #1060967 12/10/13 03:53 AM
Dude gotta find the seal. If I can get this thing figured out in so down.
Re: New Owner in Az [Re: Tetecorsa] #1060968 12/10/13 05:35 AM
Tete, I'll bring extra fluid. Just be there.
Re: New Owner in Az [Re: JohnnyBfromPeoria] #1060969 12/10/13 03:16 PM
monte3 Offline
I plan to meet Larry at the Good Egg less than 1 block north of the Chevron at 7. If anyone else is interested in having breakfast, here's the address: 34948 N North Valley Parkway. The light at the Chevron is North Valley Parkway.
See everyone Saturday. <img src="/forums/images/graemlins/cheers.gif" alt="" />
98 Gen 2.5
05 Pontiac GTO
91 Corvette ZR-1
2011 Kia Sorento (wifey mobile)
Clarkdale, AZ
Re: New Owner in Az [Re: monte3] #1060970 12/10/13 08:18 PM
That could be a plan, Monte3, I'll try to make that...yawn..."early"...
Tete, Harbor Freight has an o-ring set in metric that could be your solution pretty inexpensively. They also sell a great little set of four picks with various curves to the tips and they are also quite cheap. Might want to check them out. And I'm hooked on using Scrubbing Bubbles (Walmart has it the cheapest) as a degreaser. Fresh lemony scent instead of the gross smell from Gunk degreaser afterwards, too.
Moderated by  4x4Wire, TOASTY
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6518 MB (Peak: 0.7776 MB) Data Comp: Off Server Time: 2026-07-10 01:23:58 UTC
