'99 3.5L SOHC Valve spring compressor question #1061760 07/06/13 11:54 PM
Z
zano550 Offline OP
I'm sorry if this has been covered ad nauseum. I've read so many posts my head is spinning. I just saw a picture of a 3.5 SOHC with a valve cover removed. Here's my question: will the Snap On tool GA317 NOT work on this engine with the head still on/engine in truck? I thought I had enough info to start on a VSS replacement job, now I'm not so sure.....
Mike
99 Montero 3.5l sohc. Up and running thanks to this forum...and 7500 hrs of internet research and bloody knuckles =:o
95 Miata-slot car
99 cr250 Wait, how do you adjust the valves?
78 R100/7 Ultimate driving machine
Re: '99 3.5L SOHC Valve spring compressor question [Re: zano550] #1061761 07/07/13 12:28 AM
Canyonero Offline
The tool that works the best is the Schley (SCH91400B) Universal Valve Spring Compressor. I've used it, and it works great.
1995 Montero SR
2" Body Lift
35x12.50x15 Cooper Discoverer STT
Aisins
Re: '99 3.5L SOHC Valve spring compressor question [Re: Canyonero] #1061762 07/07/13 01:53 AM
mxmikie Offline
on the mitsubishi sohc and dohc v6 i do not think there is enough room to use the GA317
Re: '99 3.5L SOHC Valve spring compressor question [Re: mxmikie] #1061763 07/07/13 02:34 AM
Z
zano550 Offline OP
I've got the single cam engine...I've seen videos of the ga317 working easily on a dohc 3000gt...but the sohc 3.5 in the Montero looks like it has less clearance (At least in the pictures that I've seen). I'd love to know if anyone's actually used the ga 317 on a single cam 3.5 from a 99 era Montero with the engine in the truck. I'm on a severe budget and I haven't turned a wrench on this Montero. I just got it
Mike
95 Miata-slot car
Re: '99 3.5L SOHC Valve spring compressor question [Re: zano550] #1061764 07/08/13 02:13 AM
N
nckwltn Offline
answered some of your questions over here
http://www.4x4wire.com/forums/showflat.php?Cat=0&Number=1274444&an=0&page=0
I too did the valve seals in my 99 SOC. I did it with the heads still on the block, and all the main coolant lines still in place. Probably made it take a bit longer, but I didn't want to have to drain the system that I had just filled after a head gasket job.
Anyway, the most difficult part for me was removing the valve seal, followed by reinstalling the keepers.
The tool SCH91400B is exactly what I used. Again, rented from a board member for a fraction of the cost. Be sure to have a magnet handy to catch the keepers when they release.
Also, I don't think that pressurizing the cylinder head to keep the valves in place will work. Many of my keepers were stuck to the spring retainer or the valve itself. I had to apply some force on the valve via compression of the spring that would have certainly dropped it into the cylinder cavity. I ended up dropping 10 foot of flexible rope into the cylinder head (I did pressurize each cylinder to get it at bottom dead center), then turning the crank by hand to push the rope into the bottom of the valves. (google and youtube will give you a how-to)
Re: '99 3.5L SOHC Valve spring compressor question [Re: nckwltn] #1061765 07/08/13 03:04 PM
MBrannon Offline
I've borrowed and used SCH91400B in the past and it works great. In fact, I just ordered one off of Amazon so I can do VSS anytime! My favorite thing!
I have to do mine very soon. I'm smoking out the old people around here at every red-light. I've always used compressed air in the cylinder but I'm interested to try the rope trick because it seems more reliable. I'm always concerned that my compressor is going to pop the circuit breaker in the middle of the job and the valves will fall.
I have not watched the YouTube video yet, but do you simply insert 10ft of rope into the spark plug hole and then turn motor until that piston is TDC?
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: '99 3.5L SOHC Valve spring compressor question [Re: MBrannon] #1061766 07/08/13 05:08 PM
N
nckwltn Offline
Use the compressor to get the cylinder at bottom dead center. Be careful, it will move all other cylinders too, so any rags you have in spark plug holes might get blown out.
I used a 10 inch piece of 1/2 inch (or 1/4 inch, not sure of the size) to help guide the rope down into the spark plug hole. I also lifted the pvc tube up about 1/2 inch and used my air compressor to shoot air down the tube to help "shoot" the rope into the cylinder cavity.
After the rope goes in, use a wrench on the crank and turn (I think I went clockwise) until the rope is mashed up into the underside of the valves.
It worked great, and I'm glad I didn't try compressed air. After losing a keeper, I had to let the rope sit in the engine for a week while I was traveling for work, and waiting for new keepers to show up.
Re: '99 3.5L SOHC Valve spring compressor question [Re: nckwltn] #1061767 07/22/13 07:33 AM
Z
zano550 Offline OP
OK, so I removed the upper plenum today. This is the first time I've actually turned a wrench on this thing. (I hope this whole procedure works otherwise I'll have a $2500.00 Mitsubishi boat anchor...oi!!). It wasn't SOOO bad. I'll be pulling the valve covers (hopefully) next weekend. So, you used a piece of PVC pipe to help guide the rope into the cylinder? I'm not sure I completely understand =:o. I've only got a small pancake compressor and I don't trust it to hold the valves in place for a prolonged period so I'm going to attempt the rope trick....
Mike
95 Miata-slot car
Re: '99 3.5L SOHC Valve spring compressor question [Re: zano550] #1061768 07/22/13 09:22 AM
mxmikie Offline
i thought you were done with this by now
Re: '99 3.5L SOHC Valve spring compressor question [Re: zano550] #1061769 07/22/13 06:42 PM
N
nckwltn Offline
be sure you have your digi cam handy and are taking lots and lots of photos of where everything goes!
I shot a bunch of videos doing the work a few month back... I'll make some quick edits and post something up in the next couple of days.
Unfortunately my memory card ran out when I was actually getting the rope down into the cylinder, so I don't have video of that... but I might re-shoot something to give a good idea of what process I used.
I think using the compressor is a bad idea unless you REALLY know what you're doing. The nice thing about the rope is that you can stop the project close the hood, come back to in in a weeks time, and everything is ready to start again where you left it. Even with 6 foot of rope in the cylinder cavity.
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6405 MB (Peak: 0.7662 MB) Data Comp: Off Server Time: 2026-06-10 04:10:07 UTC
