Re: '99 3.5L SOHC Valve spring compressor question
[Re: nckwltn]
#1061770
07/23/13 07:25 AM
here is the video I shot back in january. my camera's memory card filled up and I don't actually have part of it.. so I tried to give an example of what I did. anyway, I just threw this together quickly http://youtu.be/AAcXAecJB-kHope it helps.
[Re: nckwltn]
#1061771
07/23/13 07:32 PM
You have to remove the compressor to remove and replace the seals, so you have to use the rope trick or the compressor trick (I prefer the former for the reasons stated above) to hold the valve with the spring and retainer and keepers removed to get at the seal, or it will drop into the cylinder. The air trick has the disadvantage of if you bump the valve stem, say while driving on the new seal, you kill the air seal on the cylinder, and down goes the valve, and the head has to come off. You don't heed 6' of rope - about 3'is enough, but more won't hurt...
[Re: fasteddy]
#1061772
07/25/13 05:50 AM
mxmikie: dude, its going to take me a while; I can only work on it once in a while. It took me a couple hours to get the upper plenum off...I could do it way faster next time. Nick and fasteddy: Yeah, when I first started researching this I was convinced I'd use compressed air...now I'm going to use rope, for sure. There's a good chance I'll have to stop in the middle of the job for days at a time, not to mention fumbling with the springs and keepers possibly dropping one in. Nick: thanks for the video, a picture's worth a thousand words on the rope insertion technique. More later. Wish me luck. BTW...is there anything I should do to/look for with the plenum/throttle body now that they're removed (i left the throttle body attached to the plenum). I plan on replacing the PCV valve
Mike 99 Montero 3.5l sohc. Up and running thanks to this forum...and 7500 hrs of internet research and bloody knuckles =:o 95 Miata-slot car 99 cr250 Wait, how do you adjust the valves? 78 R100/7 Ultimate driving machine
[Re: zano550]
#1061773
07/25/13 07:05 AM
now would be a good time to replace the heater hoses on the back of the motor
[Re: mxmikie]
#1061774
07/27/13 04:15 PM
now would be a good time to replace the heater hoses on the back of the motor Thanks, I'll look into that
