Page 2 of 3 1 2 3
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: ryany] #1061929 07/12/13 02:12 PM
MBrannon Offline OP
Mine only locks in OD, however my tranny shifts into OD and locks MUCH too early. For example, if I try to accelerate at partial throttle from 40mph to 50mph, the tranny will downshift and then almost immediately upshift again to OD and lock.
My first thought when I bought the truck last year was a bad TPS. I hooked up my OBD2 scanner and watched the TPS. Everything seemed to be fine. I'll double check it again with the method on 4x4wire. Thank you for your suggestion.
Does my 98 have different gearing than my old 95LS?
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: MBrannon] #1061930 07/12/13 03:05 PM
Yes, US Gen 2.5s with 3.5SOHC have 4.2X versus the 4.6X from original Gen IIs (oldest SRs with 4.88s aside).
Common swap is 3.5 sports that came with the 4.90s.
Also, in my past discussions with OldColt and the MT swap, he was advocating that swap first and see how the 4.2s with a 5-spd ran, then regear if still felt the need.
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: ryany] #1061931 07/12/13 04:58 PM
Angelo Offline
Maybe the pwr/eco switch is not the answer, but something is wrong with mine. The TC should not lock while accelerating. I've got some type of issue somewhere.
Check to see if your TPS is properly adjusted. There was a post recently about the proper procedure, a search should turn it up.
I had mine adjusted. Or was it the "kick down" cable? It responds better without having to mash the pedal in as much
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: Angelo] #1061932 07/12/13 05:30 PM
MBrannon Offline OP
If I swap in 4.90's from a sport, does it mess with the transfer case or gearing in the front? Does it mess with the rear locker?
1998 Montero
2007 Prius
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: MBrannon] #1061933 07/12/13 05:57 PM
Tcase wouldn't care. You'd have to do both axles for when in 4WD.
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: Angelo] #1061934 07/12/13 08:46 PM
87Montero Offline
I adjusted my kickdown cable as well to remove the slack out of it and a little more when I bought my '99... I am satisfied with the way it shifts and what not.
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: MBrannon] #1061935 07/12/13 09:28 PM
No, not the transfer case but yes the gearing in both the front and rear differential will be different. It does not affect the locker.
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: off-roader] #1061936 07/18/13 02:55 PM
MBrannon Offline OP
I received the A/T Mode switch from Brokeback yesterday. It officially does not plug and play with a Gen2.5. There is a 4 pin connector available in the truck, however the A/T Mode button is looking for 5 pins. It actually does plug in but functions exactly like the HOLD button.
Next I will try to trace the wiring for the 5th pin and see if I can add that to the 98 TCU or if I need to use an older TCU.
You guys might think I'm crazy, but my GEN2 in PWR mode was much more pleasurable to drive than it was in ECO mode. My Gen2.5 feels like it is stuck in ECO mode all of the time. I will probably not be able to investigate this issue further until next year though, so it will be awhile before I have another update.
1998 Montero
2007 Prius
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: MBrannon] #1061937 07/18/13 03:28 PM
Lloyd Swartz Offline
Are you sure its not the terrible 4:22 R&P, that makes the Gen 2.5 feel significantly under powered.
Re: PWR/ECO switch - Gen2 vs Gen2.5 [Re: Lloyd Swartz] #1061938 07/18/13 03:58 PM
MBrannon Offline OP
The gears don't help, but my tranny shifts early taking the engine completely out of the power band and then locks the TC before accelerating has completed. It's terrible.
1998 Montero
2007 Prius
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6442 MB (Peak: 0.7540 MB) Data Comp: Off Server Time: 2026-10-22 04:05:34 UTC
