Inny/ Outty Heater Core Flow Direction #1062001 07/14/13 08:10 PM
Lloyd Swartz Offline OP
Can someone tell me which side is the inlet or outlet on a 96 for the coolant going to the heater core? LOL
Re: Inny/ Outty [Re: Lloyd Swartz] #1062002 07/14/13 10:27 PM
LandRaider Offline
Please title your thread appropriately.
#3 Title your Post Appropriately. If you have a specific question, put the specifics in your title. A good example would be: Gen 2 3.5 ltr Crank bolt problems,OR My Gen1 is smoking after start up. A poor example would be Help me please my truck Suxor!! OR "Transmission"
Re: Inny/ Outty [Re: LandRaider] #1062003 07/14/13 11:35 PM
mxmikie Offline
and i thought this post was about water flow to and fro for a heater core
Re: Inny/ Outty [Re: mxmikie] #1062004 07/14/13 11:52 PM
LandRaider Offline
It is apparently.
http://www.4x4wire.com/forums/showf...4&an=0&page=0#Post650314
Here's the posting guidelines for our community.
Re: Inny/ Outty Heater Core Flow Direction [Re: Lloyd Swartz] #1062005 07/15/13 12:59 AM
ryany Offline
I don't think it makes a difference which way they're connected - it's just a loop and should be able to flow either direction without a problem.
95 Montero SR
Re: Inny/ Outty Heater Core Flow Direction [Re: Lloyd Swartz] #1062006 07/15/13 01:56 AM
stand by and I'll check the fsm. If you can see the valve, it's on the inlet line. On a gen1 the inlet linve and valve can be seen from the dside footwell. I'm lookin'...
(edit): It doesn't have a valve. Either will do, but I'd guess the inlet is the dside.tt
Re: Inny/ Outty Heater Core Flow Direction [Re: fasteddy] #1062007 07/15/13 02:17 AM
I need to know which is normally the outlet to tap into for the shower set up. Normally I just disconnect a hose and crank the engine...but that is not happening.
Re: Inny/ Outty Heater Core Flow Direction [Re: Lloyd Swartz] #1062008 07/15/13 02:18 AM
LandRaider Offline
Thank you Lloyd, and I'm jealous of your shower!
Re: Inny/ Outty Heater Core Flow Direction [Re: LandRaider] #1062009 07/15/13 07:00 AM
Oh, that makes it simple. Disco the hoses and crank the engine. Water will flow from the input hose...
Re: Inny/ Outty Heater Core Flow Direction [Re: fasteddy] #1062010 07/15/13 02:07 PM
Cant crank the engine, it is disassembled.....
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6347 MB (Peak: 0.7394 MB) Data Comp: Off Server Time: 2026-06-21 02:25:15 UTC
