Re: Turbo Raider FINALLY On The Street [Re: fasteddy] #1062318 08/04/13 12:37 AM
jonboyb Offline OP
It can read it with a little work with IO circuits but without ignition control I don't think it could do anything.
I have the lines (all flex) to move the oil cooler, just need some time.
1989 Nevada Sand Raider 2.6 5-speed
Turbo FI with Megasquirt
Re: Turbo Raider FINALLY On The Street [Re: jonboyb] #1062319 08/04/13 01:53 AM
Just curious. If you aren't using MS spark control, and are using the starion dizzy without the igniter inside, how are you making spark...
Re: Turbo Raider FINALLY On The Street [Re: fasteddy] #1062320 08/04/13 12:53 PM
jonboyb Offline OP
Sorry.....wasn't thinking. I was using a Starion dizzy and Caravan module back when I first went MS on the stock NA engine. I actually wired this one through a knock box to run a stock Starion dizzy a while back but I be danged if I remember doing it. LOL....way too many project cars. Sorry for the confusion (although now I'm confused....I guess I wire ignitions in my sleep)
Re: Turbo Raider FINALLY On The Street [Re: jonboyb] #1062321 08/05/13 01:28 AM
jonboyb Offline OP
Added some bling (and needed my shifter higher <img src="/forums/images/graemlins/lol.gif" alt="" />) Built a sleeve into it to raise and lower to my preference. If I go to a body lift in the future should be handy. Ol'school but added at least 50 hp.
Re: Turbo Raider FINALLY On The Street [Re: jonboyb] #1062322 08/05/13 02:37 AM
Shitz? You'll never get it out of second gear...
Re: Turbo Raider FINALLY On The Street [Re: fasteddy] #1062323 08/08/13 12:03 PM
jonboyb Offline OP
Have not leaned the fuel map in any boost regions yet, but cleaning up cruise regions and decel netted me 20 mpg on the current tank of gas. And it's still cruising rich of stoichometric (wideband tends to hunt in the 14.2 range) so my outlook on gas mileage is promising at this point.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6169 MB (Peak: 0.6875 MB) Data Comp: Off Server Time: 2026-06-07 10:35:18 UTC
