Page 3 of 6 1 2 3 4 5 6
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: lordtrunks] #1062578 08/18/13 08:19 PM
OK, now lets find out what tranny goes behind the 4m4 and 4m41 2.8 and 3.2 diesels...
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: fasteddy] #1062579 08/18/13 10:34 PM
87monty Offline
I want a 5 speed trans for this 4g64 setup im doing, There has to be a set up I can use and still be strong enough to handle 300+hp. I could go the Toyota 5 speed with wild bills adapters but I would prefer Mitsubishi!
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: 87monty] #1062580 08/19/13 12:55 AM
LandRaider Offline
Again... the V5MT1 is a beef tranny. It'll handle 300 hp IMO, but It is not going to shift quickly, and the ratios are going to be all wrong. The OD is not very aggressive, and you're going to be spinning some RPM's on the highway.
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: LandRaider] #1062581 08/19/13 03:19 AM
lordtrunks Offline
v5m31 is what's behind the 4m40 and 3.5 even some later 4d56's i'm not sure bout the current direct injected diesel's
the 4m40 version has the tractor low first gear.
landraider is correct these trannys are beefy but not quick shifting tranny's and the o/d's are short.
here's moby dick(v5m31)
89 2 dr turbo diesel
89/88 "Backwoods sas"
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: LandRaider] #1062582 08/19/13 04:51 PM
87monty Offline
I see, I think with the stock AT I have now im around 2300 Rpm at cruz speed on the freeway. Not as worried about that but more interested in strength and reliability. I emailed Bill on the trans adapter and all he needs is shaft length and spline count, with that info he can make adjustments for the Toyota 5 speed.
Here is a picture of one from a 99 4runner.
By the way im not trying to hijack the post just wanting to come up with a good idea and reliable solution/combo for the rigs.
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: 87monty] #1062583 08/19/13 05:02 PM
lordtrunks Offline
if your gonna have a custom bellhousing made up to bolt to a yota tranny why not go with a yota 6 spd the more ratios the better well thats the way i see it anyway
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: lordtrunks] #1062584 08/19/13 05:38 PM
This is good chit...
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: lordtrunks] #1062585 08/19/13 05:41 PM
87monty Offline
That my friend would be bad ass...At this point the possibilities are endless. what rig has a 4x4 6 speed in it?
96 SR
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: 87monty] #1062586 08/19/13 07:26 PM
lordtrunks Offline
05+ tacoma's and fj cruisers seems the fj has little a longer 6th than the taco kinda strange you would think it would be the other way around since the fj is heavier. tranny name is RA60F
here are the ratios
RA60F (Tacoma 4wd 6 speed)
4.171
2.190
1.488
1.193
1.000
0.849
RA61F (FJ 4wd 6 speed)
4.171
2.190
1.488
1.193
1.000
0.799
Re: The SR is gone.. Time to give REDCAR alittle lovin... [Re: lordtrunks] #1062587 08/19/13 08:33 PM
87monty Offline
here are the ratios
4.171
2.190
1.488
1.193
1.000
0.849
4.171
2.190
1.488
1.193
1.000
0.799
Great info! So I was in seach mode on the interwebs and found this handy website, not sure if you have seen it before but its a great tool for gear ratio's!
I love this chit!
http://www.grimmjeeper.com/gears.html
96 SR
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.005s) Memory: 0.6532 MB (Peak: 0.7748 MB) Data Comp: Off Server Time: 2026-06-07 07:24:42 UTC
