Help Please...Another Gen1 Front Hub Question - Axle Clip #1062788 08/06/13 12:45 AM
jonboyb Offline OP
Went to change my front rotors and pads tonight, and on the passengers side hub the axle lock clip behind the front beauty plate was laying loose in there. It snaps on the axle tip tight but it wasn't even on there. Shim looks intact and was still around the axle. Clip doesn't quite look like I expected either, I guess I expected to see eyelets on the ends...not blunt ends. Anything to worry about? Everything else looks great (other than separating the hub and rotor was an exercise in hammer swinging ). <img src="/forums/images/graemlins/lol.gif" alt="" />
1989 Nevada Sand Raider 2.6 5-speed
Turbo FI with Megasquirt
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: jonboyb] #1062789 08/06/13 01:35 AM
Sounds like some new clips are in order. They shouldn't be too loose, certainly not able to fall off on their own.
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: rxinhed] #1062790 08/06/13 01:48 AM
jonboyb Offline OP
It clips back on very tight....I wonder if it just wasn't installed right. Looked everywhere and can't find a part number or vendor.
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: jonboyb] #1062791 08/06/13 01:58 AM
Try mitsubishiparts.com?
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: rxinhed] #1062792 08/06/13 02:32 AM
jonboyb Offline OP
Yep, and Rockauto, etc too....all my normal Starion parts stomping grounds. Good friend is the parts manager for a local Mitsu dealership so I guess I'll get him to drag out the microfiche tomorrow...LOL.
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: jonboyb] #1062793 08/06/13 03:26 AM
I think they pop off when the axle does a maximum drop and deos it hard. I've had them pop off, too. I just whammed it back on there.
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: fasteddy] #1062794 08/06/13 12:05 PM
jonboyb Offline OP
Dangit...you mean no more Bo and Luke moves???? I can't find anything wrong so unless I can get ahold of new clips quick and easy, back on it goes for me as well.
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: jonboyb] #1062795 08/06/13 01:25 PM
jonboyb Offline OP
Clips and shims still available through Mitsu per my buddy. Will post part numbers once they arrive.
Re: Help Please...Another Gen1 Front Hub Question - Axle Clip [Re: jonboyb] #1062796 08/07/13 02:26 AM
Nah, those little jumps are ok. It's the Smokey and the bandit jumps, like the one they did over the Black Warrior River on the old US78 bridge, that do the damage.
PHP: 7.4.33 Page Time: 0.020s Queries: 15 (0.015s) Memory: 0.6285 MB (Peak: 0.7153 MB) Data Comp: Off Server Time: 2026-11-15 13:26:00 UTC
