Re: New Montero Owner 1995 SR - Saving it from the Junk Yard
[Re: ryany]
#1063126
08/22/13 01:59 PM
Wow, thanks for all the info. I have a list of stuff still to get and cooling needs to be taken care of before the snow comes. I HATE having cooling problems when the snow is out.
Planning to just replace all the rubber.
Anyone ever replaced the OEM Mitsubishi VAR Shocks? How could they be worth $300 each? I like leaving all the "gadgets" working in the truck but $1200 to keep ECS is hard to agree with.
1994+1995 Montero SR 2003 Montero Limited 1990 Mighty Max 6G72 4x4 2014 Outlander Sport (Wife) 1992 Galant VR4 (724) 2004 Mitsubishi Lancer Evo RS - (SOLD) + Other Non Mitsu's
[Re: azazel]
#1063127
08/22/13 03:48 PM
The general consensus on these trucks is to use KYB Gas-a-just shocks. They work particularly well with Monteros.
[Re: azazel]
#1063128
08/22/13 04:43 PM
Someone posted on ExPo about Parts.com having just the adjustable shock, no control unit, for rather civilized pricing. Good enough that I'd go that route, based on my liking the feature way back when I had my 95 SR.
[Re: azazel]
#1063129
08/22/13 05:07 PM
I HATE having cooling problems when it's hot out. Fixed that for ya. <img src="/forums/images/graemlins/smile.gif" alt="" /> If you think cooling problems are fun when it's snowing, imagine the enjoyment we find here in AZ when it's 110 out.
95 Montero SR 3.8 MIVEC, Advance headers, 2 1/2" exhaust, Magnaflow muffler, OME shocks & rear springs, 2" body lift, 3" tank lift, 4.90s, TRE front locker, factory rear locker, Roger Brown Rock Sliderz, 315/75r16 (35") tires, Sport big brakes
[Re: azazel]
#1063130
08/22/13 05:54 PM
I was hoping the 33's would fit without any changes/lifts needed. Looks like 33x10.5 would do the trick....not sure the 33x12.5 would work (it appears other forum posts say it wont).
I am excited to get wrenching, hurry up UPS! They do. Just may have to find a shop who will install them on the stock rims since the minimum rim width for 12.5's is typically 8.5 or 9". Otherwise, there's no interference within the wheel wells or anything else.
[Re: ryany]
#1063131
08/22/13 08:14 PM
Had a bad experience needing to put water in for a cooling problem in the winter. Then I forgot to change it and let it sit outside for a week in 0 deg weather. The water turned to ice and took out the Radiator, seals, etc. Dumb mistake!
[Re: MontyMcV]
#1063132
08/22/13 08:17 PM
Went to parts.com and looked it up. http://www.parts.com/parts/1995/MITSUBIS...component=Shock$255 is the best price I can find so far. Thanks for the info.
[Re: MontyMcV]
#1063133
08/23/13 12:43 AM
Someone posted on ExPo about Parts.com having just the adjustable shock, no control unit, for rather civilized pricing. Good enough that I'd go that route, based on my liking the feature way back when I had my 95 SR. The shocks in that thread are for the gen 2.5 (i believe) which use a different shock. Not sure if that will fit the gen II SR's or not or if the controls in cabin will work with the gen 2.5 shock. <img src="/forums/images/graemlins/frown.gif" alt="" />
[Re: off-roader]
#1063134
08/23/13 05:08 PM
[Re: off-roader]
#1063135
08/24/13 12:43 AM
I pulled the plenum this afternoon.....two butterfly valves were already gone!
One is still laying in the head, basically untouched. The other was mashed in half by a valve :-( . Time to pull the head.
I will post pictures when I clean up.
