4dr fuel tank in 2dr ? #1063194 08/23/13 03:00 AM
mike71800b Offline OP
Tanks leaking at the seams in my 89 v6.
I can find some 4dr tanks in yards, will they fit the 2dr?
Thanks
Mike
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: 4dr fuel tank in 2dr ? [Re: mike71800b] #1063195 08/23/13 03:32 AM
StockRaider Offline
No, 4dr is too big. If its a leak at the seam, find a local rad shop that would leak test it and braze the leaks. I fixed motorcycle tanks by pressuring the tank (8psi) and when finding the pinhole, sand it down and apply a thin film of JB weld then sand it flat and paint over the repair. Hope that helps. I know my 2dr tank is leaking on the top where debris and road salts collect. Doubt that will be fun...
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: 4dr fuel tank in 2dr ? [Re: mike71800b] #1063196 08/23/13 03:32 AM
No. Too big. The 4-door tank is 24-gallons, the 2-door is only 20-ish. Dimensions are much different.
Re: 4dr fuel tank in 2dr ? [Re: mike71800b] #1063197 08/23/13 03:37 AM
Thanks guys smile
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: 4dr fuel tank in 2dr ? [Re: mike71800b] #1063198 08/23/13 03:58 AM
I should have asked, how about the 4cylinder 2dr tank?
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: 4dr fuel tank in 2dr ? [Re: mike71800b] #1063199 08/23/13 04:06 AM
StockRaider Offline
nope, different mounts.
Richard E
1983 Honda XL600R
Re: 4dr fuel tank in 2dr ? [Re: StockRaider] #1063200 08/23/13 04:16 AM
Thanks for the info again!
89 v6 Raider 5spd
89 v6 Montero auto
86 TD Trooper
Re: 4dr fuel tank in 2dr ? [Re: mike71800b] #1063201 08/23/13 04:18 AM
If you need a tank, try car-part.com and look for them in snow free and saltwater free areas. <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 3.480s Queries: 15 (0.010s) Memory: 0.6218 MB (Peak: 0.7038 MB) Data Comp: Off Server Time: 2026-07-16 01:30:19 UTC
