EGR #1063211 08/24/13 02:29 AM
8
87Raider Offline OP
Help!, the vaccum line that goes from the back of the EGR valve area to the device box is blowing air (Positive Pressure), is this correct or is it supposed to have vaccum? It's not the line on the brass part,, Thank you for any info
Re: EGR [Re: 87Raider] #1063212 08/24/13 04:51 AM
Should be vacuum.
Re: EGR [Re: rxinhed] #1063213 08/24/13 07:06 PM
That port is connected to the exhaust pressure from the egr passage in the head. It's used to close the vacuum regulator valve in the device box, the one with three ports on it, and it goes to the bottom of the VRV.
Re: EGR [Re: fasteddy] #1063214 08/24/13 08:17 PM
8
87Raider Offline OP
so than its supposed to have positive pressure?
Re: EGR [Re: 87Raider] #1063215 08/24/13 08:58 PM
yes
Re: EGR [Re: fasteddy] #1063216 08/24/13 09:37 PM
8
87Raider Offline OP
It doesn't make sense to blow hot exhaust gas through a rubber vacuum line to a plastic valve. Do you have an 87? Maybe someone with a 87 could unplug the line we're talking about and verify if it has vacuum or positive pressure....
Re: EGR [Re: 87Raider] #1063217 08/24/13 09:47 PM
I had an 87, long gone. I took that info from the 87 fsm. It's not supposed to make sense, it's mitsu egr controls. And in any case, there won't be any flow thru the line if you hook it back up to where it goes.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6141 MB (Peak: 0.6916 MB) Data Comp: Off Server Time: 2026-06-13 03:12:34 UTC
