Re: Gen1 Fuel Pickup Issue
[Re: off-roader]
#1063336
08/28/13 08:40 PM
I'm pretty sure I pulled my gen1 4cyl fuel pickuptube assembly out of the front of the tank from underneath.
[Re: LandRaider]
#1063337
08/28/13 11:37 PM
[Re: fasteddy]
#1063338
08/29/13 12:57 AM
OK...now I understand after crawling under my Gen1....that is the WORST idea ever. I thought that plate was braized onto the front of the tank...didn't realize it was just screwed on. So you're relying on a rubber gasket when over 1/2 tank to prevent leakage.....I'm dang near afraid to take it loose!!!
Anyone have a picture with correct orientation in the event mine is wrong (or are the holes spaced to prevent mounting it wrong)? Just trying to figure out the fuel pickup loss with 3-4 gallons still in the tank. Thanks again guys!
1989 Nevada Sand Raider 2.6 5-speed Turbo FI with Megasquirt
[Re: jonboyb]
#1063339
08/29/13 01:02 AM
Just install it so the pickup is as low as possible. Hard to get wrong...
[Re: jonboyb]
#1063340
08/29/13 01:04 AM
It's five screws, indexing is not a problem. Pickup tube points down.
[Re: rxinhed]
#1063341
08/29/13 01:09 AM
I was just wanting to confirm I'm actually pulling from the pickup right now instead of the return line without pulling it <img src="/forums/images/graemlins/smile.gif" alt="" /> If my fuel pump is pulling off the return line....that answers my issue...LOL.
Actually....no need. Looking at those pictures the pickup is the larger diameter one. Headed outside to crawl under again!
[Re: jonboyb]
#1063342
08/29/13 01:54 AM
Nope....I have it hooked up right <img src="/forums/images/graemlins/frown.gif" alt="" />
Just a thought, I'm running a 255 lph pump and that return exits right at the pickup.....think I may be frothing/aerating the fuel when levels get low since I'm returning a TON a fuel??? Then the pickup sucking bubbles???
Guess I have to pull it no matter what to check for pinholes in the pickup tube.
[Re: jonboyb]
#1063343
08/29/13 02:23 AM
Quit stalling and take it out.... <img src="/forums/images/graemlins/lol.gif" alt="" />
The pickup sock will block the bubbles with it's mesh. IIRC, there's a rubber hose piece in there, too.
[Re: fasteddy]
#1063344
08/29/13 02:32 AM
The pickup sock will block the bubbles with it's mesh. IIRC, there's a rubber hose piece in there, too. Nothing better than going to bed smelling of gasoline....that should turn the Mrs. on <img src="/forums/images/graemlins/lol.gif" alt="" /> You mean like a rubber hose inside the sock?
[Re: jonboyb]
#1063345
08/29/13 02:58 AM
No, I take it back, since there's no fuel pump in the tank like a stock FI engine has. However, if the truck sat with bad fuel in it, you could have rust holes in the steel pickup tube...
