Re: stalling downhill [Re: fasteddy] #1063803 09/11/13 12:02 AM
W
WildTracker57 Offline OP
I did, good advice. Thanks.
Re: stalling downhill [Re: fasteddy] #1063804 09/11/13 12:39 AM
I hope you blocked the idle air port when you cleaned it. TB cleaner onto the ICM is the primary cause of ICM failure, and sometimes when an ICM fails, it shorts out the ECU...
Which causes the capacitors to fail and they end up leaking caustic fluid onto your ECU board which kills it in short order. I don't believe you can tell if this has happened without visually inspecting your ECU board. <img src="/forums/images/graemlins/frown.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5966 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-05-29 18:59:41 UTC
