Page 2 of 3 1 2 3
Re: Tire size's 31" vs 33" [Re: Grasscat] #1063897 09/15/13 03:30 AM
cap510 Offline
If 5.29s were available, I would be running 40s by now.
[b]94/95 Montero SR "rockcrawler"
Riding on 37" MTRs
Re: Tire size's 31" vs 33" [Re: cap510] #1063898 09/15/13 03:58 AM
Carlos, there are always Rockwells. 6.72's baby!
Re: Tire size's 31" vs 33" [Re: rxinhed] #1063899 09/15/13 04:56 AM
cap510 Offline
I thought about it... lol
Riding on 37" MTRs
Re: Tire size's 31" vs 33" [Re: cap510] #1063900 09/16/13 12:28 AM
mynion Offline OP
Hay all, thanx for all those replys. THem 40" tires Look SWEET...
So 33" 12.5 would those work, My Sr has the stock 2" body lift.
And is it only a slight offroad enhancement, or is it rather noticeable from the 31"
Yes, I have done some offroading on the 31"s, seemed fine... the tires are just warn down, and seeing as Im putting new rubber on anyway, figured I would ask opinions on differences...
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank.
93 600 Katana. stage 1 jet kit, Uni foam air filter
02 honda shadow. "for when the woman wants to go with"
97 Acura Integra.
Re: Tire size's 31" vs 33" [Re: mynion] #1063901 09/16/13 01:53 AM
Lloyd Swartz Offline
33's will definitely provide a significant benefit. 31's are the tire size of the 80's, and trails are set for much larger tires. You may have to mess with the inner fender behind the front bumper, bending back some metal, but that is easy.
Re: Tire size's 31" vs 33" [Re: mynion] #1063902 09/16/13 03:27 AM
No such animal... Unless you mean the one most used by those that install a BL...
IMHO, if your planning to stick to basic trails then you probably don't need 33's or greater sized tires, however if you plan on getting into doing some light to moderate rock crawling, the 33's are an inexpensive 1" 'lift'...
Re: Tire size's 31" vs 33" [Re: mynion] #1063903 09/16/13 03:31 AM
IMHO, if your planning to stick to basic trails then you probably don't need 33's or greater sized tires, however if you plan on getting into doing some light to moderate rock crawling, the 33's are an inexpensive 1" 'lift' and sometimes aka more often than not an extra 1" is the difference between making it through the trail and not making it. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
Re: Tire size's 31" vs 33" [Re: mynion] #1063904 09/16/13 03:09 PM
SR's have a stock 1" body lift over the LS model.
I ran 33x12.5 on the stock alloys with no problems.
Re: Tire size's 31" vs 33" [Re: JohnnyBfromPeoria] #1063905 09/16/13 05:35 PM
MBrannon Offline
Hey Johny, do you have any pics of the 33x12.5's on the stock rims?
Did you run at highway speeds with this setup? Thank you.
1992 VR4 12.5 @ 110 - SOLD
1993 Stealth RT/TT 11.4 @ 129 - SOLD
1991 VR4 9.2 @ 159 - Old Shop Car
1992 Stealth Twin Turbo ATX - SOLD
1990 Montero LS LWB - RIP
1995 Montero LS - RIP
1998 Montero
1992 Galant VR4 474/1000
2007 Prius
Re: Tire size's 31" vs 33" [Re: MBrannon] #1063906 09/16/13 05:48 PM
I probably do have pics somewhere. I'll look. I totally ran down a set of Toyo Open Country M/T's, so they were on there for a couple of years and I used to drive the truck for work all over AZ. It did great on the highway, no issues at all.
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.008s) Memory: 0.6423 MB (Peak: 0.7515 MB) Data Comp: Off Server Time: 2026-07-13 15:49:46 UTC
