Re: Tire size's 31" vs 33"
[Re: Grasscat]
#1063897
09/15/13 03:30 AM
If 5.29s were available, I would be running 40s by now.
[b]94/95 Montero SR "rockcrawler" Riding on 37" MTRs
[Re: cap510]
#1063898
09/15/13 03:58 AM
Carlos, there are always Rockwells. 6.72's baby!
[Re: rxinhed]
#1063899
09/15/13 04:56 AM
Carlos, there are always Rockwells. 6.72's baby! I thought about it... lol
[Re: cap510]
#1063900
09/16/13 12:28 AM
Hay all, thanx for all those replys. THem 40" tires Look SWEET... So 33" 12.5 would those work, My Sr has the stock 2" body lift.
And is it only a slight offroad enhancement, or is it rather noticeable from the 31"
Yes, I have done some offroading on the 31"s, seemed fine... the tires are just warn down, and seeing as Im putting new rubber on anyway, figured I would ask opinions on differences...
94 montero SR 3.5. 33" BFG TA KO's, OME HD rear springs, front T-bar crank. 93 600 Katana. stage 1 jet kit, Uni foam air filter 02 honda shadow. "for when the woman wants to go with" 97 Acura Integra.
[Re: mynion]
#1063901
09/16/13 01:53 AM
33's will definitely provide a significant benefit. 31's are the tire size of the 80's, and trails are set for much larger tires. You may have to mess with the inner fender behind the front bumper, bending back some metal, but that is easy.
[Re: mynion]
#1063902
09/16/13 03:27 AM
My Sr has the stock 2" body lift. No such animal... Unless you mean the one most used by those that install a BL... IMHO, if your planning to stick to basic trails then you probably don't need 33's or greater sized tires, however if you plan on getting into doing some light to moderate rock crawling, the 33's are an inexpensive 1" 'lift'...
[Re: mynion]
#1063903
09/16/13 03:31 AM
My Sr has the stock 2" body lift. No such animal... Unless you mean the one most used by those that install a BL... IMHO, if your planning to stick to basic trails then you probably don't need 33's or greater sized tires, however if you plan on getting into doing some light to moderate rock crawling, the 33's are an inexpensive 1" 'lift' and sometimes aka more often than not an extra 1" is the difference between making it through the trail and not making it. <img src="/forums/images/graemlins/cyclops.gif" alt="" />
[Re: mynion]
#1063904
09/16/13 03:09 PM
SR's have a stock 1" body lift over the LS model.
I ran 33x12.5 on the stock alloys with no problems.
[Re: JohnnyBfromPeoria]
#1063905
09/16/13 05:35 PM
Hey Johny, do you have any pics of the 33x12.5's on the stock rims?
Did you run at highway speeds with this setup? Thank you.
1992 VR4 12.5 @ 110 - SOLD 1993 Stealth RT/TT 11.4 @ 129 - SOLD 1991 VR4 9.2 @ 159 - Old Shop Car 1992 Stealth Twin Turbo ATX - SOLD 1990 Montero LS LWB - RIP 1995 Montero LS - RIP 1998 Montero 1992 Galant VR4 474/1000 2007 Prius
[Re: MBrannon]
#1063906
09/16/13 05:48 PM
I probably do have pics somewhere. I'll look. I totally ran down a set of Toyo Open Country M/T's, so they were on there for a couple of years and I used to drive the truck for work all over AZ. It did great on the highway, no issues at all.
