Page 2 of 3 1 2 3
Re: Towing a Dodge Raider Automatic V6 [Re: Grasscat] #1064009 09/18/13 03:11 AM
...or make up some full-floating rear axle parts and manual hubs?
Re: Towing a Dodge Raider Automatic V6 [Re: rxinhed] #1064010 09/18/13 05:10 AM
geocrasher Offline
Did any Montero's ever have full floaters?
http://tidbitsfortechs.com/
Re: Towing a Dodge Raider Automatic V6 [Re: geocrasher] #1064011 09/18/13 05:58 AM
Grasscat Offline
OK I'll bite, what's a full floater?
Michael j
TreadLightly! Trainer
Re: Towing a Dodge Raider Automatic V6 [Re: Grasscat] #1064012 09/18/13 07:31 AM
geocrasher Offline
It's what all front axles are. Imagine the whole hub/bearing arrangement without all the steering, and in the back. They can break an axle shaft and all that happens is that the wheel is no longer driven. The GM 14 bolt axle and the Ford 10.25 axle are both full floaters, as are all semi truck driven axles.
Re: Towing a Dodge Raider Automatic V6 [Re: geocrasher] #1064013 09/18/13 09:30 AM
LandRaider Offline
No monteros ever came full float rear.
http://www.youtube.com/watch?v=_aVj7JSpSpU 4:48 specifically.
Rge advantage is that if you break an axle shaft, your whole wheel and all doesnt fall off. The axleshaft is only used to drive, not support.
Re: Towing a Dodge Raider Automatic V6 [Re: LandRaider] #1064014 09/18/13 04:14 PM
and you can pull axle shafts without even removing the wheel, just unbolt the bearing cover. You can usually recognize them by the round bolted cover over the axle stub.
Re: Towing a Dodge Raider Automatic V6 [Re: fasteddy] #1064015 09/18/13 08:48 PM
Isn't towing in tranny neutral with the engine running an option? Albeit prolly not the most ideal. It could be the option for those rainy times when he doesn't want to crawl underneath...
Re: Towing a Dodge Raider Automatic V6 [Re: MontyMcV] #1064016 09/18/13 11:17 PM
Grasscat Offline
Yes, I've done that several times, but only travel less than a 100 miles or so. The temperature stayed in the normal position as if I were driving it.
I would do it again, but I now have a 5 speed.
Michael j
Re: Towing a Dodge Raider Automatic V6 [Re: Grasscat] #1064017 09/18/13 11:54 PM
I once flat towed a 73 Plymouth Fury repo from Hobbs, NM to Birmingham, AL with the engine idling. No problems with that part. Otherwise, it was a horror story.
I would modify the tcase shift rail to have a detent slot for the neutral postion, either by installing a m/t tcase shift rail, that has the notch, or by grinding a notch in the a/t tcase shift rail. This will require removing the tcase in either case (not terribly hard), removing the shift rail, and swapping it (I don't know that the m/t shift rail will fit for sure) or modifying it. There is a check ball in the tcase, there's just no notch in the rail for it to catch. This mod has been done before...
Re: Towing a Dodge Raider Automatic V6 [Re: fasteddy] #1064018 09/19/13 12:52 AM
I like that story.
"The car we were towing pulled out to pass..."
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6421 MB (Peak: 0.7509 MB) Data Comp: Off Server Time: 2026-10-24 20:03:39 UTC
