Page 4 of 4 1 2 3 4
Re: 91 Monty front end squeal [Re: fasteddy] #1064459 10/23/13 03:59 AM
9
91LongBox Offline OP
iirc I did research it. It was on a prior post here. The goodyear website doesn't specify Montero, I was going off what you said you had run for years.... ?
sh$t creek survivor
1991 Montero LS 4 door V6
1987 Raider 2 door 4 cyl SOLD
Re: 91 Monty front end squeal [Re: 91LongBox] #1064460 10/23/13 04:41 AM
9
found correct item from Febi Bilstein part number W0133-1618848, ordered thru Auto Parts Network. Having it overnighted, as I cannot wait any longer to get this pulley on. When I receive part I will let all know if its the answer to my problem. Cost is $40, plus I overnighted for additional $16. Will advise.
anybody have a 91-93 benz 500 series they need a pulley for...cheap ?
sh$t creek survivor
Re: 91 Monty front end squeal [Re: 91LongBox] #1064461 10/24/13 07:49 PM
9
Part arrived and it took less than 10 minutes to replace worn pulley. After several attempts tightening the adjuster head bolt on "center" idler pulley, (again, one at 5pm using the alt as a clock)she now makes NO noise. So nice driving down road without the squeal ! I also learned (and correct me if I'm wrong)that I needed to make sure the adjusting head bolt was pretty tight to alleviate the tiny little squeal still there when I first installed new idler pulley.
I'm hoping this "tightening" sequence doesn't mean that perhaps the alt pulley is making some noise and because I tightened her up pretty good, it quieted it down ? Can anyone tell me just how tight the serpentine belt should actually be ? Mine is on there pretty snug.
sh$t creek survivor
Re: 91 Monty front end squeal [Re: 91LongBox] #1064462 10/26/13 10:16 PM
9
The squeal is back. Two days of silence . Its not as pronounced, but its there. It will go away after a bit. Now it's got to be narrowed down to either the alt pulley or (gasp!) the water pump ? Accepting advice....
sh$t creek survivor
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6091 MB (Peak: 0.6657 MB) Data Comp: Off Server Time: 2026-06-17 04:20:03 UTC
