What other wheels fit Montero?
#1064613
10/04/13 10:08 PM
Just wondering what other wheels fit the Montero SR? I have looked at current FJ cruiser wheels but center bore seems to be too small. Anyone have any luck with others? Ford, GM, etc?
'94 Montero SR --------------------
Re: What other wheels fit Montero?
[Re: MichaelV]
#1064614
10/04/13 10:19 PM
Just wondering what other wheels fit the Montero SR? I have looked at current FJ cruiser wheels but center bore seems to be too small. Anyone have any luck with others? Ford, GM, etc? Must be 108mm center bore. Most arent even though the rims used have that size center bore.
[Re: MichaelV]
#1064615
10/05/13 03:40 PM
Just wondering what other wheels fit the Montero SR? I have looked at current FJ cruiser wheels but center bore seems to be too small. Anyone have any luck with others? Ford, GM, etc? Black Rock D-window.
[Re: Fujisawa_Rob]
#1064616
10/05/13 04:26 PM
older style chevy,nissan,mitsubishi,isuzu,toyota rims.Alot of the newer style 6 lugs have the wrong center bore.
1991 Montero RS
[Re: SledgeHammer]
#1064617
10/05/13 06:30 PM
older style chevy,nissan,mitsubishi,isuzu,toyota rims.Alot of the newer style 6 lugs have the wrong center bore. I think Isuzu and Toyota wheels are hub-centric. Maybe...
[Re: Fujisawa_Rob]
#1064618
10/05/13 09:17 PM
Most of the wheels can be thought of as hub centric, though in practice may be nut centric. Aftermarket wheels are the easiest to find. However, you can also use Montero Sport wheels, 16" and 17" diameter. Otherwise, just buy a grinder and hog them babies out! :~)
[Re: rxinhed]
#1064619
10/05/13 10:27 PM
Most of the wheels can be thought of as hub centric, though in practice may be nut centric. Aftermarket wheels are the easiest to find. However, you can also use Montero Sport wheels, 16" and 17" diameter. Otherwise, just buy a grinder and hog them babies out! :~) Cool. Isuzu made some nice looking wheels. Is there any Japanese OEM that equipped with 15x8 alloys? I've not seen anything in 15" wider than 7".
[Re: Fujisawa_Rob]
#1064620
10/06/13 01:48 AM
older style chevy,nissan,mitsubishi,isuzu,toyota rims.Alot of the newer style 6 lugs have the wrong center bore. I think Isuzu and Toyota wheels are hub-centric. Maybe... I have swapped all of them around on each others vehicles,they all fit fine.I have had yotas on my chevy,chevy on my Isuzu and Isuzu on my chevy,nissans on my Mitsubishi etc. 90% have been 15 rims.hardly ever went bigger
1991 Montero RS
[Re: SledgeHammer]
#1064621
10/06/13 05:02 PM
To be clear, Toyota steel wheels will fit: Isuzu rims fit the rear, but not over the 4wd hub on the front: See grinder comment above, as this will be necessary for some of the rims suggested...or prepare for disappointment. Correct information was presented in the second response.
[Re: rxinhed]
#1064622
10/07/13 12:59 AM
Isuzu rims fit the rear, but not over the 4wd hub on the front: Snowflakes!
