Page 2 of 10 1 2 3 4 9 10
Re: Another SAS coming [Re: StockRaider] #1065143 10/28/13 08:05 PM
tonygon Offline OP
my Raiders front diff is completely worn out and I don't feel like rebuilding it. So I am looking into chopping my IFS off and going solid axle. Ive talked to Toasty about this a bit, and figure the cheapest route would be a Waggy axle leaf springs, and then eventually get more complicated suspension down the road. I just need to find the right axle before I start with my cutting torch <img src="/forums/images/graemlins/lol.gif" alt="" />
Yup! We're on the same page!
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: Another SAS coming [Re: tonygon] #1065144 10/29/13 12:27 AM
tonygon Offline OP
Anyone know hot to ID my ring gear size without droping the 3rd?
Re: Another SAS coming [Re: tonygon] #1065145 10/29/13 12:58 AM
The 96 SR only came with the 3.5L DOHC engine so that ring gear should be a 9.5" gear with a 4.6x:1 r&p ratio. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Another SAS coming [Re: off-roader] #1065146 10/29/13 02:24 AM
tonygon Offline OP
Thanks off roader <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Another SAS coming [Re: StockRaider] #1065147 10/29/13 02:38 AM
87monty Offline
ummm this sounds interesting... you have my attention too.
What year/model is your axle from?
will go great with my jeep trans and tcase <img src="/forums/images/graemlins/smile.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Another SAS coming [Re: 87monty] #1065148 10/29/13 02:58 AM
tonygon Offline OP
Im actually not sure what year. Its from a grand waggy and drivers side drop obviously. The guy i bought it from had it under an xj and doesnt know the year either. Im halfway cutting the coil buckets and mounts his guy put on it. BTW this axle had a nasty hack job that involved high steer without flat top knuckles... It was nasty... I already have flat tops and will be replacing all the wearable parts anyways. Shafts are good.
Re: Another SAS coming [Re: tonygon] #1065149 10/29/13 04:50 AM
87monty Offline
Right on man sounds like a cool project.
I think the straight axle is a good swap because you rid of the cv's and all the week sh*t that would break under hp or big tires for sure. What are you going to do about the 5 lug bolt pattern?
(Update)
Google searched and found this in a forum.
I did a Dana 44 out of an 89 Wagoneer as they are stronger and are also 6 lug rather than 5 x 4 1/2.
Rusty's Offroad sells the upper control arm brackets needed to attach to the differential to make it work and also the spring buckets and shock perches pre-fabbed. All you need to do is find a buddy that's good at welding and you can have it setup pretty easily.
Re: Another SAS coming [Re: 87monty] #1065150 10/29/13 05:10 AM
The AMC-era Wagoneer should be passenger side drop and 6-lug. The Chrysler-era Wagoneer should be driver side drop and 6-lug. When disc brakes were added to the FSJ in 1975, there was a switch from 5-lug (drum) to 6-lug for the 1/2-ton.
Baldy used the coils and DS drop D44 from a 78/79 F-150 and swapped on 6-lug outers. Look up his posts on the subject of his D50.
Re: Another SAS coming [Re: rxinhed] #1065151 10/29/13 08:06 AM
LandRaider Offline
This is what I used for my SAS.... Search about it, and you will find most of your work is already been done. smile
Re: Another SAS coming [Re: LandRaider] #1065152 10/29/13 11:30 AM
What is what you used LandRaider????
PHP: 7.4.33 Page Time: 0.018s Queries: 15 (0.015s) Memory: 0.6469 MB (Peak: 0.7526 MB) Data Comp: Off Server Time: 2026-07-15 02:14:39 UTC
