Page 4 of 10 1 2 3 4 5 6 9 10
Re: Another SAS coming [Re: LandRaider] #1065163 11/03/13 07:56 AM
LandRaider Offline
Quotes of myself out of those threads.
Bottom line is that a wagoneer D44 is the ultimate answer for dirt cheap axle.
Bolt pattern for the wheels is the same, it is 2 inches wider than the rear axle, it is drivers side drop, it has every locker option on earth made for it.
You can dream about getting a 60, or a portal, or even a rockwell, but the priuces to fit those are hellabucks.
IF I were going to do a coil setup, I would study the crap out of stock suspension setups. Then go look at a long arm TJ setup. Take measurements, and pitcutes, and more measurements and pictures. Then go buy some steel tube, spring buckets, and more steel, and go to town. Start duplicating.
The main advantage I see to coils is that you can mount the axle further foward, and not have a front leaf spring mount sticking out. If you did it right, you could extend your wheelbase, and have a 0 degree approach angle.
You will also hear alot of web wheelers criticizing leafs, and such as inferrior, or not worth doing a SAS. Alot of that is hooey, and you have to look at who is saying it also. ALOT of that speak comes from people who have NO experience with either.
OF course I would rather have coils!!! but hey... the added ease, and simplicity of a leaf setup made it worthwhile for me to go that route.
As for angles.. I basically duplicated the wagoneer. I made that axle think it was going right back into the wagoneer it came out of. Caster angle, all of it.
Safety is also pretty important here guys. Remember.. You have to get on top of this creation, and drive it 70 mph down the interstate. IF a weld breaks, and a control arm comes off.... If a steering joint pops out.... You are going down in a blaze of stupidity. and unfortunantly you might take someone with you.
LOL this made me laugh.
Re: Another SAS coming [Re: LandRaider] #1065164 11/03/13 08:01 AM
LandRaider Offline
Detailed SAS pics.
http://alliedpaper.org/landraider/
Just scroll down to SAS pics. I will answer any questions you may have on this subject.
Re: Another SAS coming [Re: LandRaider] #1065165 11/03/13 04:56 PM
(Almost) Everything you were afraid to know, and asked about.
Thanks for doing the research on your threads, Curtis. As I stated above, it's not that difficult. Just looked up LandRaider and go. Hah, hah, hah!
<img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Another SAS coming [Re: rxinhed] #1065166 11/03/13 06:45 PM
LandRaider Offline
I THINK I just found my Picture Archives. If so I will rehost SAS pics for all.
* All Orig SAS pics have survived. I will post a link to them all shortly.
Re: Another SAS coming [Re: rxinhed] #1065167 11/03/13 06:59 PM
LandRaider Offline
You're all quite welcome.
Re: Another SAS coming [Re: LandRaider] #1065168 11/03/13 07:16 PM
LandRaider Offline
https://imgur.com/a/lqGmc#0
Let's see if this works.
Re: Another SAS coming [Re: LandRaider] #1065169 11/03/13 08:15 PM
87monty Offline
Found a good write up you guys might like.
I'm looking for one as well:) Will work great with my jeep set up in the Montero.
http://www.therangerstation.com/tech_library/Dana44.htm
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Another SAS coming [Re: 87monty] #1065170 11/05/13 06:39 AM
Great info there.
Re: Another SAS coming [Re: Mudraider] #1065171 11/05/13 02:34 PM
tonygon Offline OP
Great info there.
Agreed. Thanks to all for sharing the great info and knowledge <img src="/forums/images/graemlins/kewl.gif" alt="" />
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: Another SAS coming [Re: tonygon] #1065172 11/08/13 05:03 AM
So it sounds like the width difference is minimal since I am using the SR rear axle. It looks like from all my surfing, the axles all have manual hubs. That will help to lower the costs, can have a LIncoln locker. Would have to save money to get that 4:56 ring and pinion
PHP: 7.4.33 Page Time: 0.013s Queries: 15 (0.010s) Memory: 0.6520 MB (Peak: 0.7589 MB) Data Comp: Off Server Time: 2026-07-15 15:41:34 UTC
