What springs? Gen 1lwb #1065235 10/23/13 07:39 PM
1
1morebike Offline OP
I'm going to replace my shocks and springs and was planning on going with ome but have read a few threads saying there not all that great. I have no plans of lifting my truck and plan on 31x10.5 tire . What's your advice?
1990 5sp lwb 274,000 miles 80,000 on new motor
Re: What springs? Gen 1lwb [Re: 1morebike] #1065236 10/23/13 08:03 PM
geocrasher Offline
Howdy! Shocks: KYB Gas-a-justs. Springs- no lift needed for 31's smile Unless you're just looking for height, in which case I don't know. 31's fit great on gen1's like my Raider and there's no rubbing and it looks just right. Higher isn't necessarily better, anyway.
http://tidbitsfortechs.com/
Re: What springs? Gen 1lwb [Re: 1morebike] #1065237 10/23/13 11:06 PM
ryany Offline
If you're not looking to lift your vehicle, why do you want to replace the springs? Unless they're sagging there really is no need to get rid of the originals. If they are sagging then another pair of OEM springs is all you need.
I've got OME springs on my Gen II and couldn't be happier with their ride and performance. What sold me on them originally was that throughout my research, OME was the only company I found that actually engineered their products specifically for the Monteros, and designed & tested their shocks and springs as a package to work together. Most shock manufacturers that have shocks that "fit" Monteros are not specifically tuned for them - they'll make a shock that physically matches the original shocks and select an off-the-shelf damping rate based on the weight of the vehicle and the stock spring rates.
95 Montero SR
Re: What springs? Gen 1lwb [Re: ryany] #1065238 10/24/13 12:28 AM
1
I'm looking at replacing the springs because the truck has 275,000 miles on it and they are sagging pretty good.
Re: What springs? Gen 1lwb [Re: 1morebike] #1065239 10/24/13 01:41 AM
ryany Offline
A set of Gen II rear springs would work well for you - they are progressive rate instead of constant rate like the original Gen I springs, and they'll give you a 1/2"-3/4" lift over stock.
95 Montero SR
Re: What springs? Gen 1lwb [Re: ryany] #1065240 10/24/13 02:32 AM
1
Gen 2 ones sound nice got a link to order some? Do they fit without modification?
Re: What springs? Gen 1lwb [Re: 1morebike] #1065241 10/24/13 06:50 AM
ryany Offline
I believe they are a direct replacement.
Walker Renton Mitsubishi used to be the go-to for online Mitsu parts but my link for them goes to a NJ dealership now. Bruce Titus Mitsu is online here; http://www.mitsubishiparts.net/partlocator/index.cfm?siteid=218241 but you might be able to find lower prices at other online dealers. You might also try to find the best price online then see if your local dealer will match that.
Checking the used parts listings on this forum or your local Craigslist could nab you some used ones for far less - I sold my originals for $50 when I upgraded to OME.
95 Montero SR
Re: What springs? Gen 1lwb [Re: ryany] #1065242 10/24/13 03:45 PM
Struc Offline
I'll put in my vote for:
https://www.jnztuning.com/oempartscat.html
for new OEM parts. Guys are great, pretty good discount off list price, and they will find what you need even if it means checking stock in Japan. It can take 2-12 weeks to get a part out of Japan, though. <img src="/forums/images/graemlins/lol.gif" alt="" />
Curt Shambeau
87 Mitsubishi Montero SWB (Turbo G64b wideblock conversion soon)
Re: What springs? Gen 1lwb [Re: 1morebike] #1065243 10/25/13 02:08 AM
Mitch Offline
I used to work in the Olympia area a few times a year. There was a decent pull your own parts place near Tumwater. Seems like it was very near a small airport. That would be the cheapest way to go. Seem to recall one down near Tenino also. Pulled parts from both and carried them home on the plane.
89 Mitsubishi 2dr. V6, winch, Snorkle w/FF boot, Aisin's, sway bar discos, 15x8 rockcrawlers, 33X12.5 BFG MT's, KV85's, Snorkle install
94 Toyota x-cab, totaled
99 Dodge 2500 diesel, sold
Re: What springs? Gen 1lwb [Re: Mitch] #1065244 10/25/13 03:09 AM
1
im not to concerned about money just want nice set of springs. the ome ones are $163 for the pair but people don't seem to really like them. i found some 1992 oem ones for $170 apiece. maybe ill just go ome and see what happens
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6284 MB (Peak: 0.7367 MB) Data Comp: Off Server Time: 2026-05-27 00:04:00 UTC
