Gen1 3.0 engine issues #1065329 10/28/13 11:47 PM
RECON45 Offline OP
I do not know what it is, but the last couple of days the little raider has been acting up. The other morning it was cold and it died after a quarter of mile and took a few minutes to crank when 20 feet and died. Got it fired up to go up the hill and it wanted to bog down like an old carburated engine when it is flooded. as long as i did not step on the gas and just lightly pressed it. The raider made it up the hill and was able to park. 2 hrs later I am able to drive home no issues.
The other day i was driving and it stall/hesitated for a second and then drove fine. The temperature was fine but it did happen within a mile of the house when i 1st cranked it up.
Any ideas?
Re: Gen1 3.0 engine issues [Re: RECON45] #1065330 10/29/13 03:08 AM
MarkG Offline
Fuel pump - Or some restriction in the fuel delivery system. The symptom that caught my eye was only able to lightly press the accelerator. The fuel pump wasn't able to supply enough fuel to allow you to open the throttle much.
Re: Gen1 3.0 engine issues [Re: MarkG] #1065331 10/29/13 07:19 AM
Or the ecu coolant temp sensor, if it's been cold in the am...
Re: Gen1 3.0 engine issues [Re: fasteddy] #1065332 10/30/13 01:51 AM
RECON45 Offline OP
I will keep an eye on it
PHP: 7.4.33 Page Time: 3.532s Queries: 15 (0.003s) Memory: 0.6020 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-06-10 05:18:30 UTC
