Page 2 of 8 1 2 3 4 5 6 7 8
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065736 11/03/13 03:11 AM
geocrasher Offline
I like the all wheel drive option for sure. The case is massive and build very well. The adapter is a little crude but functional. Iv put a lot of time and effort into making this work out. Should be really fun to drive behind the 4g64 power plant.
This is very, very cool. When do you plan on making these available to those of us who might be so inclined?
http://tidbitsfortechs.com/
Re: Mixtubishi trans has been pulled off! [Re: geocrasher] #1065737 11/03/13 05:12 AM
87monty Offline OP
I feel after all I have accomplished on this,it maybe in my best interest to have a much better template cut out using a water jet method. im working with a friend to make this happen. I will keep you posted on that for sure.
As for the trans case you would have to send that to me for the machine work. Not a expensive deal at all.
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065738 11/03/13 06:26 AM
geocrasher Offline
Sounds pretty awesome <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: geocrasher] #1065739 11/04/13 02:13 AM
Slave cylinder pulled and ready to go. smile
Clutch master cylinder cap sun rotted and friable, can't send it to you. <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: rxinhed] #1065740 11/04/13 03:54 AM
87monty Offline OP
Thanks for the parts you did have Russ! inching ever so close. Next on the list is to install the clutch/break pedal assy.
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065741 11/18/13 01:50 AM
87monty Offline OP
So I have been slowly rebuilding my transmission with upgraded parts, Here it the new HD clutch.
Here is the new upgraded toyota 5th gear bearing(left)
Here you can see how the new bearing has a needle bearing all the way across instead of the stock weaker design,
96 SR
Re: jeepabishi trans has been pulled off! [Re: 87monty] #1065742 12/06/13 01:08 AM
87monty Offline OP
So my goodies came in, New Toyota 5th gear set and small parts kit with snap rings. The Toyota G54 and G58 are the same transmissions as the Ax jeep trans other that the rear tail housing which can be swapped around <img src="/forums/images/graemlins/smile.gif" alt="" />
And Look three pedals!!!!
Re: jeepabishi trans has been pulled off! [Re: 87monty] #1065743 12/10/13 04:02 AM
87monty Offline OP
Gear box is just about together,
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065744 12/31/13 06:37 PM
87monty Offline OP
I made a custom clamp/retainer on the lathe to hold the snap ring on the 5th gear main shaft. This is the only weak link that has been known to reek havoc on the trans. you can buy one from this website http://www.allstategear.com/AX5%205th%20GEAR%20SNAP%20RING%20RETAINER.htm
but I felt 4 bolts is better than two:D Time to put the case back together and prepare for the install <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065745 01/01/14 03:53 AM
We could do a similar thing to run the V5MT1 bellhousing on the Toyota 5 speed i'm assuming?
PHP: 7.4.33 Page Time: 0.013s Queries: 17 (0.010s) Memory: 0.6535 MB (Peak: 0.7772 MB) Data Comp: Off Server Time: 2026-07-14 10:42:05 UTC
