Page 5 of 8 1 2 3 4 5 6 7 8
Re: Mixtubishi trans has been pulled off! [Re: geocrasher] #1065766 03/20/14 02:10 AM
Malykaii Offline
Might be tough to do it for 750... aka rebuild price. You need custom drive shafts. Thats a few bucks right there. Just saying.
But i also agree. Whats the news. Driving around with it yet?
88 Montero, StarQuest turbo, Kormex 5speed +tuff-pan w/phoenix f. stage2 clutch, 4in lift+33' tires, 4.875 lsd, short-throw shifter, Aisin hubs, SR big brakes, gen2 uca's, elantra alt, and so much more... 16g turbo w/hardpipes + 4.90 locking disk-brake axle soon (maybe lsd or aussie front??)
Re: Mixtubishi trans has been pulled off! [Re: geocrasher] #1065767 03/21/14 09:51 PM
87monty Offline OP
Any progress on this? If I could do this swap for the price of a KM145 rebuild, I would.
Hi Guys thanks for asking, the trans is done and ready to go in at this point.
I have decided to go with the waggy front axle as well (SAS Jeep just makes sense) So that is in the works now. I have the axle and im figuring out my front coil setup. I will only need to make a custom rear drive line ( may go Sr rear disk too later) The front will just need to be shortened from what I measure. I will not know for sure tell its all together. My work will be slowing down so I will have more time to get it all done.
Honestly from having the Km145 next to the jeep/toyota trans I wouldnt use one. This 5 speed is built way better all around and has a larger input bearing. Plus its the same as the toyota G54 <img src="/forums/images/graemlins/kewl.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065768 06/08/14 10:46 PM
87monty Offline OP
Found a good link on some trasfer case info. I figured this would be a good place to put it <img src="/forums/images/graemlins/notooth.gif" alt="" />
http://www.jeepforum.com/forum/f13/transfer-case-swap-info-np249-np231-np242-685644/
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065769 07/01/14 04:14 AM
87monty Offline OP
So for all that want an update, I am a few weeks away for the install of this trans. I ordered a new aftermarket trans mount and need an rear drive line part thanks to Tony (Tonygon) here on the wire doing some foot work.
Can't wait!
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065770 07/01/14 03:36 PM
I'm excited to see this work, is there a CAD drawing available for the adapter? I may have asked this already.
On a side note you have inspired me to Mix up the Mitsu and Toyota auto transmissions. With lordtrunks' help i think we've figured out how i can run the Toyota gear driven transfer cases and under drive boxes. <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: TOASTY] #1065771 07/01/14 07:49 PM
87monty Offline OP
Thanks Toasty! We are working on a cad drawing as we speak.
Sounds interesting on the combo your thinking of doing. Can't wait to get this finely done!!
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065772 07/03/14 08:04 PM
87monty Offline OP
Thank's to Tony (Tonygon) Great jeep to mitsu flange adaper Idea! I found this bad boy. You will need to drill holes in your stock mitsu rear dif flange but it will be a bolt on after.
http://www.dennysdriveshaft.com/p1939_da...ord_7.5_an.html
Fixed the link.
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065773 07/03/14 08:51 PM
tonygon Offline
Sweeeeet!
1988 MONTERO SWB 2.6L 5SPEEED MANUAL, 96SR LOCKED REAR, 8INCH FRONT LSD FRONT, AISIN MANUAL HUBS, CUSTOM F & R BUMPERS, ROCK SLIDERS, TUBE HALF DOORS, 9K WINCH, HOMEMADE SNORKLE, SOME OTHER STUFF.
Re: Mixtubishi trans has been pulled off! [Re: tonygon] #1065774 07/23/14 12:43 AM
87monty Offline OP
So this is the last thing I needed to get done! After I come back from my Vacation to Washington( middle of Aug) I will put it in!!! I am also working on a AX15 adapter, Same thing just a little bigger <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065775 07/23/14 02:18 AM
That's looks like a pretty rough grind to me. Hope the machinist doesn't do heads that way.
PHP: 7.4.33 Page Time: 0.013s Queries: 17 (0.010s) Memory: 0.6530 MB (Peak: 0.7756 MB) Data Comp: Off Server Time: 2026-07-14 10:48:08 UTC
