Page 7 of 8 1 2 3 4 5 6 7 8
Re: Mixtubishi trans has been pulled off! [Re: TOASTY] #1065786 10/17/14 01:03 AM
87monty Offline OP
I did the opposite of that with my Toyota axle swap, The Toy centering bore is smaller than on the Montero so I had to make a downsizing ring for the Mitsu flange to accept the Yota yoke.
Good work dude!
Thanks Toasty! it's stuff like this that is very time consuming, but well worth the effort in the end result.
I want this to hold up for a long time!!!
Project is coming along great, two more weekends of coaching soccer and im free at last to really get stuff done <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: TOASTY] #1065787 10/17/14 04:06 AM
Good looking yoke, after it's cleaned up. <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: rxinhed] #1065788 10/18/14 09:38 PM
87monty Offline OP
Thanks Russ it cleaned up great!
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Mixtubishi trans has been pulled off! [Re: fasteddy] #1065789 12/01/14 01:00 PM
plh Offline
The part I like the best is the nvg242 tcase. All the benefits of selectrac in an nvg case with all the options that makes available...
Which vehicle and model year did the 242 come from? Looks like a cable driven speedo so it must be '88 to '91 and I assume it is a 21 spline input to match to the AX5?
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Mixtubishi trans has been pulled off! [Re: plh] #1065790 12/02/14 05:34 AM
87monty Offline OP
Hi Phl, I think it was a 1990 and yes 21 spline unit.
I can ask but im pretty positive that's the year it came from. I do have the AX5 tranny in my Montero and fits really nice. I went with a Np 231 for now because you have to run both front and rear drive shafts with the NP242.
After I install the dana 44 I will go with the AWD <img src="/forums/images/graemlins/smile.gif" alt="" />
96 SR
Re: Mixtubishi trans has been pulled off! [Re: plh] #1065791 12/02/14 05:35 AM
87monty Offline OP
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065792 12/02/14 02:55 PM
plh Offline
Fantastic information. Thanks. Would also be helpful if you added the part numbers for the AX5 upgrade. I assume they are from Toyota - except the gear retainer which you built.
  • '88 Raider: my OG
  • '92 RS M/T: sold
  • '14 OL GT
Re: Mixtubishi trans has been pulled off! [Re: plh] #1065793 12/02/14 08:00 PM
87monty Offline OP
No problem, I will check into my parts list and report back.
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065794 12/02/14 08:22 PM
87monty Offline OP
Here you go! These guys are great to work with and parts are priced right.
5th gear set,
http://cobratransmission.com/toyota-g40-g52-g57-g58-g59-5th-gear-set-50045054-1
5th gear needle bearing (Must have, this is a one piece bearing, an upgrade from the Ax5 split bearing crap)
http://cobratransmission.com/toyota-g40-g52-g57-g58-g59-5th-gear-needle-50045028-1
Rebuild parts kit(Must have)
http://cobratransmission.com/ax4-ax5-small-parts-kit-5000019-1
Front input shaft seal
http://cobratransmission.com/ax4-ax5-seal-front-5000017-1
I can run 456 gears and 35" tires all day long with these upgrades.
Cheers <img src="/forums/images/graemlins/cheers.gif" alt="" />
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065795 12/03/14 03:37 AM
87monty Offline OP
So I cant seem to leave things alone. I built a custom cross member using the outer sections of the stock unit.
the transfer case is hanging off the back of 5 speed with no support(Factory). So I made a bullet proof one <img src="/forums/images/graemlins/smile.gif" alt="" />
The center rubber mount isn't bolted up yet because I need to pull it back down and give er a paint job.
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6521 MB (Peak: 0.7591 MB) Data Comp: Off Server Time: 2026-10-24 03:15:47 UTC
