Page 6 of 8 1 2 3 4 5 6 7 8
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065776 07/23/14 02:30 AM
haztoys Offline
Mr 87monty..I would like to thank you for going out of your way and taking your time to do this ...
Now if I may ask ...Your cutting and milling a mitzu trans bell housing to get your bell...
What about the removable bolt on bell on the Mazda/Mitsu motored trucks...?
Re: Mixtubishi trans has been pulled off! [Re: haztoys] #1065777 07/23/14 05:02 AM
plh Offline
Would be easier in my opinion, will still need an adapter in similar thickness (maybe not exact thickness) '87 and I chatted about the removable bells early on. I have a V5MT1 bell for a 4 cyl bolt pattern (from diesel) and we compared measurements. Very close. I'd expect the Mazda/Mits dimensions are similar. The AX5/AX15 input shafts are longer than the KM145, so not only need the adapter to make up the bolt pattern differences, but also to be used as a spacer.
Great project for sure!
  • '83 Might Max: IG @83mmax
  • '88 Raider: my OG
  • '89 Raider: rescued
  • '92 RS M/T: sold
  • '93 SR: sent to crusher
  • '05 Montero LTD: sold
  • '18 PHEV: wife's daily
  • '14 OL GT
  • http://www.tuffpans.com
Re: Mixtubishi trans has been pulled off! [Re: rxinhed] #1065778 07/23/14 05:34 AM
87monty Offline OP
That's looks like a pretty rough grind to me. Hope the machinist doesn't do heads that way.
It may look that way but its pretty smooth.
Should be a good brake in for the clutch disk. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2003 limited 20 year anniversary
96 SR
87 Montero SWB=Turbo diesel 4BT
T19 4sd with 205 transfer case
Re: Mixtubishi trans has been pulled off! [Re: haztoys] #1065779 07/23/14 05:39 AM
87monty Offline OP
Thanks its been a great experience and fun to be honest. As for the bolt on bell I think that would be very easy to come up with. all you would need to figure out it is the thickness of the adapter to get your end result.
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065780 10/02/14 03:58 AM
87monty Offline OP
Just a update I have all the parts needed(it's about time)
I will start the tear down this weekend. I have been staring at this trans for ever and she needs to be in. Iv also upgraded to ss clutch line, should feel nice and solid.
Stay tuned....
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065781 10/04/14 03:47 AM
MartySoCal Offline
An adapter to fit the AX-15 would also fit the NV3550 jeep trans, with a higher torque rating and a 4.0-1 first gear.
Have you figured out the pilot bearing yet? Early AX-15's use one size, (15mm). 1992 and later ones used a larger nose on the input shaft, as do NV3550's (.750").
Re: Mixtubishi trans has been pulled off! [Re: MartySoCal] #1065782 10/04/14 04:42 PM
87monty Offline OP
Have you figured out the pilot bearing yet? Early AX-15's use one size, (15mm). 1992 and later ones used a larger nose on the input shaft, as do NV3550's (.750"). [/quote]
The only thing that would need to be done is having the flywheel machined out to fit the bigger pilot bearing.
Also making sure the clutch disk would stay in the maximum
Surface area. All that's left is adapter thickness to get the right spacing for the trans input shaft. To me this project has proved anything's possible if you plane it out.
96 SR
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065783 10/15/14 05:09 AM
87monty Offline OP
So I have made a ring for the bigger rear drive shaft yoke.
I made it out of 1/4" plate. for a perfect fit, it needs to be tight to make a good tig weld. This is what my dimension's are 3.945 ID x 4.750 OD perfect to drill holes for a nice solid mount. I tried to upload a picture but had some weird 404 error when I clicked on it?
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065784 10/16/14 11:42 PM
87monty Offline OP
I was able to add pictures with photobucket. it seems they have made big improvement's and plan to use them again <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Mixtubishi trans has been pulled off! [Re: 87monty] #1065785 10/17/14 12:39 AM
I did the opposite of that with my Toyota axle swap, The Toy centering bore is smaller than on the Montero so I had to make a downsizing ring for the Mitsu flange to accept the Yota yoke.
Good work dude!
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6521 MB (Peak: 0.7753 MB) Data Comp: Off Server Time: 2026-10-24 02:26:21 UTC
